Question about Haier HWR08XC5 Thru-Wall/Window Air Conditioner
Air Conditioning The air conditioner sprays water everywhere.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
An air conditioner of this type always has standing water sitting in the base-tray of the machine as it's running. They're designed to work that way. However, if the unit leans slightly in toward the inside of your house, then the water in the tray can be deeper than it should and/or add extra humidity to the inside air. These units are designed to be installed so that they lean slightly to the _outside_ of the window or wall-hole where they are mounted. This way the standing water drains off to the ground outside and isn't so deep that it gets hit by the fan. Check the mounting of this unit to make sure it leans slightly toward the outside. Also verify that any notch or drain hole on the outside end of the unit, intended to guide draining water, is not clogged with debris (which could also cause the standing water in the unit to be at too high a level). Doing these things will make sure that the water in the base-tray of the unit won't get caught up in the fan and sprayed everywhere. And, in case you need it, the Users Manual is available for download at this URL: --> http://www.haier.com/products/product.asp?proID=3558 Hope this helps! ;)
Posted on Aug 06, 2007
  • lauraadcock_ Aug 21, 2011
    My Haier Window Air unit is displaying an E1. Manual URL is not working. Can anyone help
Where do I put water in this air conditioning portable unit
Usually air conditioning units don't need water. In fact it most likely "produce" water as it takes off humidity from ambient air.
but to be sure, you can find the user manual online with model number maybe?
Sep 01, 2018 | Heating & Cooling
How do you drain water
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.If your need any other air conditioning help check out Air Conditioning Repair Tamarac we will be sure to answer any question you have.
Jul 28, 2016 | Heating & Cooling
WHAT IS THE MINIMUM TEMPERATURE OF COOLING
most home air conditioners go as low as 18 c but this low setting achieves nothing but a high power bill
the purpose of air conditioning ( air conditioning -- to condition the air) is to remove the humidity ( water vapour ) form the air and allow the body to perspire more freely and so is by the evaporation of the perspiration of the body water that cools the body
this evaporation is hastened by the fact that the water vapour in the air is very low due to the air conditioner operation of conditioning the air
Now knowing this fact it is obvious that all the windows and door should be kept closed ( to remove the humidity from the room /house and so a setting of 25-26 c is sufficient to keep you cool
because the temperature difference between outside air and room air is low the air conditioner cycles less frequently and costs less to run
if the room setting is at minimum and the atmospheric temp is high then the air conditioner is running virtually all the time
so instead of asking what is the minimum temp you should be asking what is the optimum temp run to be conformable and to save on power costs
Jun 26, 2015 | Heating & Cooling
How to fix a leaking air conditioning unit
you need to specify the leak. is it water. in this case you need to open the cover, check the drainage cable and either use a thin metalic hanger to clear any plugged drain or you can use a canned air power spray.
Sep 05, 2014 | Samsung AS18A6RB Air Conditioner
Does this air conditioner need water
Air conditioners don't need water. if it is runnibng properly and blowing cold air it will produce water on the condensing coil. Look at the coil. If you see a lot of ice, turn the unit off and wait until the ice melts. If the ice returns it is probably low on freon. This must be taken care of by a licensed air conditioning tecnician.
Nov 17, 2012 | LG BG8000ER Air Conditioner
After spraying off the unit the display shows e1
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 12, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Air conditioner not cooling
This is a tell tale sign that your condenser coil on the rear of your upper unit is dirty. You need to get up on the roof and remove the shroud from the unit. Gently spray into the condenser with a water hose until the water that is coming out is clean. This is a good procedure to do once or twice a year to help the efficiency of your unit.
Hope this helps.
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
My 1998 gmc jimmy blows hot hair when i turn on the air conditioning, how much does it cost for the freeon recharging?
you can do this your self it takes 134a however make sure low psi switch is working located on left side in accumalator neht to lg freon line suction they go bad you can jump it out with a small piece of wire on the plug side if gets real cold than switch bad if not low on gas make sure front coil is clean spray out with mild soap and water hope this helps
Jun 09, 2009 | Goodman CKL36AR36 Air Conditioner
Daikin air conditioner leakin water at a fast rate
You should have access to the condensate drain from the outside. You can use compressed air to unclog the unit. If you can, try accessing the drain from the source outward but be careful, you can blow debris everywhere. Make sure you have something to catch it so it doesn't spray everywhere. If you don't have access to compressed air, you can use a small plumbing snake to work you way up the pipe. Hope this answers your question.
Mar 20, 2009 | Heating & Cooling
Haier HWR08XC5 Thru-Wall/Window Air Conditioner Logo
187 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bonded Repair
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
