Question about Panasonic Microwave Ovens
Door does not close
Door safety lock system has got one hook type bracket snapped from the door body so the door is not making the click noise when we close it as a result the micro wave does not operate.
  • Panasonic Master
  • 9,098 Answers
Panasonic calls that part the "door key" and it's not too difficult to replace.
You have to separate the door panels (as shown in the attached photo) and then you'll see how things go together.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Jan 03, 2009
One of the hooks on the door is broken. Why has oven stopped working?
The 'hook' on the door is a door catch and it has safety interlocks in the sockets in the body of the microwave. The door has to be firmly closed and all the safety interlocks in place before the microwave will operate.
http://panasonic.eu/ServiceCenter/en_GB/index_uk.html
Feb 07, 2016 | Panasonic Microwave Ovens
Microwave door alignment
test all this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 27, 2013 | Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
R-1481 start button won't work
I have a r-1482 model so I don't know how close they will be. The biggest issue I found so far with my particular model, yours my be the same, is the door safety micro switches fail primarily from opening the door while the unit is in the process of cooking which causes them to arc and burn the contacts resulting in premature failure. With an ohm meter, check the resistance of the contacts of each switch individually with the COM terminal lug temporarily removed and ensure the closed resistance is 0 ohms and infinity when the contacts are open. Measure from the COM terminal to the terminal in use either N.O. or N.C., with the switch button NOT depressed the N.O. will be open while the N.C. will be closed and with the button depressed they will be opposite, in other words N.O. will be closed and N.C. will be open. Another thing to check is that the door hooks aren't broken (they activate the safety switches. Should you remove the switch bracket to replace the micro switches, make sure you wire the switches exactly the way they were COM to COM, NC to NC & NO to NO, mount them in the bracket the exact way they were and adjust the bracket so that the switch buttons are just to the point of being fully depressed and no more when the door is fully closed. The micro switches may be different in model numbers but you can sub with a micro switch that has all three COM, NC, NO terminals and only use the terminals in use for the given switch. I used Omron p/n: D3V-16G-1C25-K from Mouser Electronics (800) 346-6873. Since you didn't indicate the control panel was not operational I won't go into that area. I can't say if the timer will count down or not if the micro switches are bad, but it's a possibility, further pointing to the switches. If the control panel or MW tube is bad it's my recommendation to buy a new oven, though you can get new MW tubes, diode & capacitor, it's not worth the shocking experience to the human body, not to mention the MW radiation.
Good luck if you still have the oven and decide to take it one step further.
Jul 19, 2012 | Sharp R-1481B Microwave Oven
Jenn air microwave loose door
Most if not all of these units have a safety switch--can't get at it from the outside---if unit is taken apart it often is snapped into a plastic holder and prevents the unit from working if door is open.
If it is loose or not engaged completely the unit will do what you are describing.
Jun 15, 2012 | Jenn-Air Microwave Ovens
The door latch won't close. The light stays on. Display kept saying close the door.
The problem is an engineering defect. The mechanism that engages the door latch is mounted to a steel plate that is "L" shaped and when you close the door it pushes against and bends this plate out of position. After a while the metal plate fatigues and stays bend out of position and the door stops engaging and locking so the two safety switches inside don't get depressed. Result door won't lock and light stays on. I had to re-engineer it by cutting the tube of a pen to size and placing it in as a support bracket to put pressure on the plate so it won't bend anymore. My wife was going to throw it in the trash. Note of caution: I did cut my hand in several places trying to get the bottom cover on and off the microwave as the metal edges are razor sharp!!! I love this microwave it is my second one.
Dec 22, 2010 | Panasonic NN-T990SA Microwave Oven
Microwave Problems
I just had this issue happen to me last week.. fortunately I was standing in my kitchen when it happened... I heard a snap and then a piece fall down the inside of either the door or the front key panel.. I'm assuming this controlled the door locking/oven turning on safety mechanism. The inside light wont go off and it won't turn on to cook.. I am trying to figure out if it's worth paying to fix or just replace the whole unit!? Anyone know if this is fixable by oneself rather than spend a bunch of money on a service technician??
Jul 28, 2010 | Sharp R-1610 Microwave Oven
Door won't stay closed
May 28, 2010 | Sharp R-1610 Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
