Question about Roper RGX4634KQ Gas Dryer
Heat stops after ten minutes
The dryer keeps running but with no heat
  • Roper Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
uty
Posted on Sep 30, 2010
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
We have a frigidaire infiniti dryer AEQ6500CFGO it runs for about ten minutes an shuts off, lights on right hand side blinking and no heat! Ive replaced main board and same problem? Help plz! :)
Check the airflow, one way to do this is unhook the dryer from the ductwork and let it run with a wet load of clothes to see if it stops. If it does not then the issue is lack of airflow because of the ductwork. If it does stop then the issue is because of overheating somewhere else.
Jun 28, 2015 | Frigidaire Dryers
Affinity Dryer has all LED lights blink and then it stops running
Hello everclavel - Try reprogramming the dryer by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the dryer could possibly be experiencing a communication error with the main control board, wiring failure, or faulty door lock assembly. Connect with a certified technician to move forward accurately to assist with the repairs.
Jan 29, 2013 | Frigidaire Electric Dryer
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Dryer will stop heating after ten minutes...
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Apr 28, 2012 | Dryers
GE Dryer works but keeps stopping after only 5 minutes
IT SOUNDS LIKE YOU NEED TO REPLACE TERMOSTATS.
Oct 19, 2009 | Dryers
Dryer runs for ten minutes then stops
there is not a whole lot of info here......but it could be that your timer dial is worn out! on the other hand dryers have thermal protection switches to keep them from over heating! (FIRE!) you could have a few different problems if this is happening.
May 24, 2009 | Dryers
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
108 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
