Question about Sony Handycam DCR-DVD105 DVD Camcorder
I mistakenly taken out my DVD out of the sony 605E without finalising it. I am not able to playback it in the PC or even see it in the Camera........
  • hdove77 Apr 27, 2009
    I have the same problem and now it asking me to format my disc. What do i do now?
  • 41 Answers
Try this - Put the disk back into the camera and try recording a further short clip. If that works then finalise and try playing back in camera/on PC. It may help.
Posted on Feb 03, 2009
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
I recorded video from my Sony Handycam to the RH387H HDD and then wrote the video onto a DVD-R disc using the XP setting (instead of SP, LP.....). The disc can only playback now on the LG387H, but cannot...
make sure the disk is finalised after recording, if this does not help then the bit-rate it uses for xp may not be compatable with other dvd players, in which case stick to sp,lp or dual-layer sp is best if ou can.
Jan 25, 2011 | LG RH1999H DVD Recorder/HDD Recorder
Need help with playback
you have to finalize the video first and need to do it otherwise you cant because i have a sony and everytime i finalise it then i play the video finalizing option is in option menu
Apr 13, 2008 | Canon DC20 DVD Camcorder
Dvd to prints
You can either
1. Transfer the still pictures from the camcorder to the PC, and then, either
1.1 use your PC software to print the pictures, or
1.2 use an online photo processing lab to print the pictures for you.
OR
2. Take the disc from the camcorder to a local photo printing shop and ask them to print the pictures you want printed.
But first ...
before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
You also need to make sure that the DVD drive on your PC is capable of reading a DVD-R, DVD-R DL or DVD-RW format as these are the only disk formats that the DC210 will handle. Not all PC DVD drives can read these formats.
To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then, switch on the camera, put it into playback mode, Press 'Func.', select main menu, select 'disk operations', select 'finalise'. Don't move or shake the camera or switch it off whilst the finalising step is underway - this could cause problems.
Once finalising is complete, take it out of the camcorder and then follow steps 1.1, 1.2 or 2 above.
Good Luck.
Apr 11, 2008 | Canon DC210 DVD Camcorder
How to copy from CANON DC210 DVD Camcorder to PC
Before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
Once finalising is complete, put the disk into the PC.
Good Luck.
Apr 03, 2008 | Canon DC210 DVD Camcorder
Will not play on computer
Good Luck.
Mar 25, 2008 | Canon DC210 DVD Camcorder
Transfering from canon dc210 to my pc
Good Luck.
Mar 19, 2008 | Canon DC210 DVD Camcorder
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Mini DvD-RW problem
You've recorded your video and you're ready to view it on a PC.
Now you need to finalise the disk before you can see it on the PC, otherwise the PC will not be able to read it.
To finalise the disk, connect your camera to the power adapter, plug the adapter into a wall socket, and switch on the wall socket, then switch on the camera.
To get to the finalise step. switch on the camera, press FUNC (on the top left side of the camera), move the joystick down to get to MENU, press SET on the joystick, move the joystick down to get to DISC OPERATIONS, then select FINALIZE, using the SET on the joystick. Finalising will now start.
Make sure you do not move the camcorder or switch off the wall adapter during finalisation - this could cause problems.
Feb 23, 2008 | Canon DC210 DVD Camcorder
Sony Handycam DCR-DVD105 DVD Camcorder Logo
115 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
