Question about GE Profile JT952 Electric Double Oven
GE Elec oven JT952-30" blinks the "lock" after self-clean
GE Electric oven model JT952-30" continues to blink "lock" after we self-cleaned. Only cleaned the bottom oven. We can get the door to open, but it will not allow us to use the oven...can't set a bake setting. The oven "clicks" continuously. We are able to use the top oven.
  • bobhinds57 Jan 06, 2009
    Probably exactly the same but close. We attempted to self clean the top oven and it did not complete and not it indicates the door is locked. We tried to hold the button for 3 seconds as indicate dont he oven but it remains locked. Do I need to call a technician?
  • GE Master
  • 19,396 Answers
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
Frigidaire oven won't lock door for self cleaning oven, oven beeps and blinks oven door locked. Help!
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 17, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
GE electric range with self cleaning oven. When
try to unplug power from wall and wait 30 min,then turn on
Jul 05, 2009 | Ovens
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
General Electric JKP45 Double Oven
Don't know why repairman couldn't order parts you have your model #. The model # is the JKP45WV1WW, The part # is WB26K5030 for the lock motor.
Jun 30, 2008 | GE JKP45 Electric Double Oven
JTP56 Self Cleaning issue
It sounds like you need to replace the door latch assembly. One of the switches on it is not working properly so the control is not getting the correct signal for the door latch position. It could be an oven control problem, but most likely it is the latch.
Post back with the complete model number from the oven if you need more help and I will answer as soon as I can.
Thanks, Mike
May 06, 2008 | GE Profile JTP56 Electric Double Oven
"Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Mar 31, 2008 | GE Profile JTP56 Electric Double Oven
Tappan electric stove designer series
the cleaning light and the lock door light doesn't go on when I set them to self cleaning and lock the door what should I do
Nov 17, 2007 | Tappan 30IN ELEC IGNa Oven
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Gleb30tsa
find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
May 31, 2007 | Frigidaire GLEB30T9D Electric Double Oven
GE Profile JT952 Electric Double Oven Logo
513 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
