Question about Canon PC-795 Copier
LIGHT BUT DISTINCTIVE DARK STREEK TOP TO BOTTOM ON ALL COPIES
Each page I copy has a dark streek about 1/4" wide from top to bottom, I have taken out the cartrage but no help. Is this internal to the copier and is costley to fix? Should I buy a new copier?
    Novelist:
  • 148 Answers
You do not need to replace the copier
the cartridge has a charger wire that you can clean with a pencil erasure
Also remove glass and clean the underside of the glass and the mirror
finally
open the fuser area( exit area where you clear jams and remove the wiper / cleaner of the fusr rollers
ad reinsert
look for any lines on the rollers
when you install the toner cartridge lift the shutter that exoses the imaging drum to see if it looks ok
if it has lines on it you may have to replace it ther is a wiper (silicone that will get toner nder it and can cause the lnes
All you can do is reinsert ant try it if it persists relace the cartridge
Posted on Jan 02, 2009
Why are copies dark at top, light at bottom? - Canon IR 3300 Digital Copier but computerice print is ok good
1. Glass could be dirty, smoggy
2. Lid that is not closing on the one side.
3. Scanner unit faulty.
Nov 06, 2015 | Canon Ir 3300 Black & White Copier
Backlight
It is not the fault with its back-light I assumes. Might be of T'Con board. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Make it sure.
Jun 24, 2013 | Sanyo DP46849 46 in. HDTV
Copies have dark areas extending from top to bottom of page
try to adjust the exposure adjustment to adjust that press the lock lever open to clamp shell then adjust the rotating vr there is a number indicate adjust to lower number then try to test a copy if its work
Dec 31, 2009 | Canon PC-920 Black and White Copier
Visible "streek" down the length of my copy
usually this is caused by dirt or wite-out on the scanner glass. List the feeder and clen the scanner glass.
Nov 23, 2009 | Office Equipment & Supplies
All in one x7550 is leaving wide black lines on copies and even on faxes sent out--what's the problem??
The problem is likely the scanner. Both copies and faxes are scanned. Tell it to scan an image. Lift the top, so you can watch the light bar go down the page. Its most likely got a dark area.
If under warranty, make arrangements to get it repaired or replaced. If not it may cost as much as a new printer. It has to be taken apart to replace the part.
Oct 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Aficio 1035 Drum problems
if you clean the drum unit, but the copy is dark push the drum unir forward because the luck is not locked
Feb 07, 2009 | Ricoh Aficio 1035 Copier
Canon screen problem
It sounds like your camera has encountered either a bad CCD issue, which is the image sensor capture device under the lens. Usually when it goes bad, you get crazy colors, or problems with the image. Or you might have a broken LCD, which can be replaced for fairly cheap as well. It is kind of hard to tell from your description with the problem. There is a pretty good company that might have a replacement CCD for you, they usually sell them for cheap 15-25 dollars, or a replacement LCD for around 60-100 dollars.
You can find them at www.darntoothysam.com
Dec 02, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PC-795 Copier Logo
130 people viewed this question
old marine
old marine
