Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag topload washer stops during any point of cycle buses and
Smells electric hot . you can shut off wait a while and somtimes it will resume operation or not. dont know for sure but somtimes it seems like you can move adgitater or move tub back and forth and turn back on and it will restart. it just buzzzez like motor cant start but is trying. does this sound like a intermitent problem with motor and would it buzz if tripped on thermal overload?
  • 1 more comment
  • marklbrock Jan 02, 2009
    what would you check first motor, control board whats the cheepest, do i just start throwing money at it?? good used washers dont cost as much as some of the parts let alone the time to repair. will it Buzzz if the motor is tripped on an thermal over load? Can you give estamated cost of new control board?
    no belt on this model. drive from motor is a coupling to gear box or trans. pump on other side of motor.still no one has comment on my direct questions?? how can i test motor etc?
    On the money, checked contacts and one was not making good contact, a little tweak and some fine emry cloth fixed this frustrating problem. tborn6 really hit the nail on the head! Thank you for sharing your knowledge.
    Top Expert:
  • Maytag Master
  • 77,499 Answers
Without a load u can't test the motor unless it is burnt out and doesn't run, here is what u look for, the insulation coating on the field coils should be an amber color, kind of like wood varnish when it is dried, if the motor has been overheating u will see that this coating is very dark, in many cases almost black, it will smell burnt as well, this means the motor has been overloaded or is starting to fail, what causes this? it can be the transmission is having a problem that creates excessive drag/load on the motor, this could be bearings, the motor could also have a problem such as a shorted field winding, this reduces the power of the motor and makes it work harder to keep up with the load, the result, it overheats.
Posted on Jan 02, 2009
    Genius:
  • 1,239 Answers
HI
 you will need to set the washer in the agitate portion of the regular cycle. once it starts humming you will need to make 2 voltage checks.AND CHECK THIS https://www.rezspec.com/cms_download.php?mod_files%5Bfileid%5D=000000000463 -maytag topload washer stops during any point of cy - ec2a34d.jpg
    Sergeant:
    Novelist:
  • 326 Answers
I would suggest to check out for the motor.
The motor drives the spinning tub and agitator during wash, damp dry and spin cycles. The pump removes water from the tub and lifts it out to a drain or laundry tub. The pump may be attached to the drum drive motor directly or with a separate pump belt. On some newer machines, the pump is a separate unit with its own drive motor, which is directed by the timer or control circuit board at the appropriate time to drain the machine. Most pumps have a limit of how high or at what volume they can push water from the machine.
In one direction, the motor works through a clutch and/or a transmission to spin the wash tub at speeds from 400 to 800 rpm in top loaders and 600 to 1500 rpm in front loaders. This spinning forces water, by centrifugal force, out of clothes and into the outer tub. This water is then pumped out to a drain. Most top loaders have a two direction or reversing motor.
In the opposite direction, the motor works through the same clutch and transmission to move the agitator back and forth during the wash cycle. Modern front loaders usually have a variable speed reversing motor but no clutch or transmission since there is no agitator to move back and forth. The spin and wash speeds are controlled through circuit boards, which speed up or slow down the frequency of the voltage supplied to the drive motor.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, perhaps your best bet would be to perform visual inspections. A few ideas you may want to consider/explore, try or check:
  • the highest power consumer on any washer would be the heater (if one is installed) or the motor.
  • being so they would most likely cause the electric burning smell;
  • the motor will heat up and eventual burn itself if the tub/drum have a difficulty turning, too loaded or the bearings are shot/stuck;
  • the smell could also be the belt slipping (if your model uses that as a motor coupler to tub/drum);
  • if the cycle will continue/push through and finish when you give the tub a helping push, then it is possible that the starting capacitor (if used) is faulty and could also cause the electric hot smell;
  • in most units, there would be a tech sheet with wiring diagram taped to one of the panels. The wiring diagram would come in handy when troubleshooting if the problem is electrical in nature. Please post back the specific model of your Maytag Washing Machine (or confirm that it is a MAV6000).
Good luck and Thank you for using FixYa. Happy New Year.
    Sergeant:
  • 311 Answers
Mark turn the motor by hand it should move freely.it dose have a protector init like a curcit breaker.also on those the pump pully drags metal to metal and can cause motor to kick onto over load.boards average around 100$ but i dont think you need one
    President:
  • 1,990 Answers
This is Definately the Motor. I would absolutely start at that point.
  • 916 Answers
The first thing I would do is check the drum and make sure it is not catching on anything. Next I would check to make sure the belts are on correctly. If nothing is catching and the belts are not loose but there is buzzing and nothing is happening the problem is the motor.
  • 700 Answers
There are a points in the timer switch that have to be made for the washing machine to work correctly and also down below where the motor is there is also a set of contacts that make for the unit to work. Look byu the motor and there should be a block where the contacts make to energize the motor. that is where the burning smell is probebly coming from. take and check the contacts and if they are really burned up thats what you have to replace.
    Brigadier General:
  • 5,158 Answers
I would suggest it's a belt that is loose
  • Maytag Master
  • 19,396 Answers
That looks like a short on wirings, or a faulty control board.
All parts must be tested and eventually replaced.
Enter model number here to find assembly diagrams and parts.
  • 1 more comment
  • Ginko
    Ginko Jan 02, 2009
    You start checking the control board, by taking apart the control assembly behind the timer control.
    You use a multimeter to test it.
    If this tested reads fine, then you test wires, motor and motor control unit. to test this parts you access the back of the appliance, undo belt routing, access and test the part, using multimeter , energizing parts (motor) testing MCU etc.
    The easiest part to access is control board.
    Also gaskets must be checked, to ensure the smell was not just a gasket torn because of a spinning problem.
    Most of this tests are not suitable for an home reapir and for safety reasons must be done by a technician.
  • Ginko
    Ginko Jan 02, 2009
    "no belt on this model. drive from motor is a coupling to gear box or
    trans."
    Does not change anything, belt does not smell like burning, and direct traction does not either, at least not in this way, this parts are not involved.
    "still no one has comment on my
    direct questions?? how can i test motor etc?"
    Thesting the motor requires you putting the head at the back of the machine, and energizing the motor directly, after checking if there are traces of burnt on the motor wirings, and if the motor is stiff.
    The motor is powered at 110V and this kind of test must be done by a qualified technician.
    I cannot tell you to do this yourself, because if you get fried I will be jailed for life, I think this is clear enough.
    All tests and repairs (particularly ones with live power, but not only) must be done by a qualified technician.
  • Ginko
    Ginko Jan 02, 2009
    By the way, stating to your description, the most likely is the control board, check that first.
My maytag washer frequently shuts off during cycle ,but resumes after i open and close the lid
It is an indication of an unbalanced load. There is a mechanism that trips the safety switch that you trip when you open the top. by cycling the top, you reset the switch. Always include a model number and age.
Nov 06, 2013 | Maytag Washing Machines
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
My washer keeps pausing during the cycle
Hi claire64 - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and resume cycle. If fault reoccurs, then it typically means that the unit either has a faulty door latch assembly or a communication error from the control board. Since there are cost differences in parts, it is always a good idea to have a service tech properly diagnose your appliance.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
GE front load washer shuts off mid cycle
you will need to contact manufacturer to get it repaired
Jan 03, 2013 | GE WCVH6800J 27" Front-Load Washer with...
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
