Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
Clogged screen for White Westinghouse washer
White westinghouse washer 8 cycle super capacity, Cold water dribbles into washer. when hose removed, water flows fine from house valve. hot water flows fine into washer. Have well water; believe screen is clogged but cannot find a screen to clean???
  • nancydashner Jan 03, 2009
    I went back and checked the hose...we had not originally seen the screen as it is coned shaped. With a tooth brush and a screw driver it cleaned up quickly and fixed the problem...thanks!
  • 34 Answers
The screen is located inside the water valve. you will need to take the hose of of the valve and take a small flat screw driver and pull the screen out
Posted on Jan 03, 2009
Water does not drain during spin cycle. Tub spins, but water remains in the tub.
Water pump is out. Will need a new pump.
Only other possibility is your drain hose is clogged check that first.
Drain Pump Part #: AP5684706 Runs about $95:
Frigidaire 137221600 Drain Pump AppliancePartsPros com
Apr 18, 2014 | Westinghouse WWS833ES Super Capacity Top...
White westinghouse 8cycle washer will not spin or drain now it wont do anything model number WW5833ES1 i thought it might have been circuit related so i reset the fuse box and removed the clothes from the...
does it fill with water yet?if so then its the lid safety switch that gone bad under the top lid,this will kill all cycles other than fill,if it doesn't fill with water either then the timers defective
Jan 01, 2011 | Westinghouse WWS833ES Super Capacity Top...
I just replaced the belt on my White WESTINGHOUSE la 560axw2 WASHER. It is now severely out of balance whenever it reaches the spin cycle.
The problem may be with the top springs may be damaged you can replace the spring set completely to get the smooth running in the spin
Dec 30, 2009 | Westinghouse WWS833ES Super Capacity Top...
No cold water from washing machine. Hot water is fine.
You have to replace the cold water solenoid valve.
Oct 05, 2009 | Westinghouse Washing Machines
Cold water dribbles in rinse cycle, hot and warm water fine
If you check the warm water flow you'll likely find it is HOT...and not warm. Check the faucet end of hose to see if screen is clogged. Should be screened washer with the dome portion of the screen facing out at you. Remove it and clean with brush to remove grit or scale from screen. If you find nothing there you need to replace the water fill valve located at the other end of the hoses. Good Luck
Aug 23, 2009 | Kenmore 22422 Top Load Washer
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
278 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Chris Hall
Chris Hall
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
