Question about Denon AVR-4306 Receiver
New Unit Overheating...
So I have this AVR-4306. It was NIB, but had been sitting for god knows how long before I got my hands on it. It's overheating, BADLY. Different music heats it up faster as well. (Metallica burns it up) Anyway, after a short period of time (5-15 minutes) with the volume over 3db, it turns off. But when I say hot, I mean too hot to touch hot. Burns your fingers hot. The heat is eminating from the Heat sink, which runs the depth of the unit. No abnormal heat is being produced by the AC/DC converter. Any suggestions?
  • Anonymous May 28, 2008
    Over heating and then turns off when playing DVD at high
    volume
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
  • 151 Answers
SOURCE: install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 20, 2008
  • 5 Answers
SOURCE: DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Posted on Sep 11, 2008
  • 92 Answers
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
Posted on May 18, 2009
Turk_97
  • 138 Answers
SOURCE: Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Posted on Oct 13, 2009
How can i upgrade denon avr 4306 up to 1080p?
You don't need to upgrade that model as it already supports 1080P. If you are using HDMI connections between the receiver your TV the receiver will upconvert the other analog video sources (composite and component video) to 1080 content. Most likely 1080i as this is the standard format when upconverting.
Feb 28, 2011 | Denon AVR-4306 Receiver
Hi Jim,
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Surround sound not working
Bad DSP board (digital signal processing board)- a common problem for Denon receivers. Hope you have a warranty.
Apr 06, 2009 | Denon AVR-4306 Receiver
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
On screen display
Try connecting to the yellow RCA monitor output on the amp and corresponding input on the TV. This works for me. You could also try the composite outputs on the amp. This is one flaw the amp has that the setup screen will not display through the HDMI connection.
Aug 04, 2008 | Denon AVR-4306 Receiver
Install ps3 on avr-4306
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Clicking sounds
i had this condition on another denon a/v receiver it started clicking got worse as time went on progressed to snaping sound more so when switching modes ie dvd to tv etc then l/frt speaker would cut out found by gently tapping l/side of the chassis it would pop & snap sent it out to denon & they replaced the dsp unit no problem since hope this helps Alan
May 22, 2007 | Denon AVR-4306 Receiver
Coonecting receiver to computer
If you are using a Windows OS then you will need to go to the speaker icon on the bottom right of your screen and open the menu that allows you to select the line in input. Good luck.
Apr 12, 2007 | Denon AVR-4306 Receiver
Open Questions:
See all Denon AVR-4306 Receiver Questions
Denon AVR-4306 Receiver Logo
130 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
