Question about Saeco Magic De Luxe Espresso Machine
Main switch not working
Received rebuilt unit as a x-mas gift. Power supply confirmed. Unit does not respond to main switch operation. Does this machine have an internal fuse? Where do I look?
  • Anonymous Jan 14, 2009
    same problem no power to unit ? internal fuse?
  • 3 Answers
There is a slow blow fuse on the motherboard.  Easy enough to replace once the top is taken off, and the motherboard removed. You need Torx & Philips head screwdrivers.  There are guides how to remove it on the net.
Posted on Feb 19, 2009
E000012-0106
The machine cannot be operated and the error code <E000012> appears on the display.
Cause and Solution
The delivery feeder unit may not be installed correctly. Follow the procedure below to install the delivery feeder unit correctly. If the error code persists after the delivery feeder unit is installed correctly, contact your local authorized Canon dealer.
Re-install the Delivery Feeder Unit
NOTE
  • You have to remove the delivery feeder unit and reinstall the delivery feeder unit correctly.
  • When you remove the delivery feeder unit, you have to turn the main power switch OFF.
  • Sending or receiving documents cannot be done when the main power switch is OFF or the power cord is disconnected.
  • If the main power switch is turned OFF, all jobs waiting in the print queue will be erased.
  • Documents received into memory and documents stored for delayed send will be retained for approximately 60 minutes after the power cord has been disconnected.
1. Turn OFF the main power switch and disconnect the power cord.
2. Open the front cover.
If you are using the stack bypass tray, close it before opening the front cover. Open the front cover gently holding the handle (A).
3. Push the levers (A) on both sides of the delivery feeder unit and remove the delivery feeder unit gently, holding it by the tabs (B).
CAUTION
Do not place any object on or touch the transfer belt (A) of the delivery feeder unit. You do not need to manually clean the transfer belt even when it is stained by toner, as the delivery feeder unit has a self cleaning function for the belt. Breaking the delivery feeder unit or damaging the transfer belt may result in misfeeds or deterioration in print quality.
4. Install the delivery feeder unit so that the protrusions (A) of the delivery feeder unit fit into the guides (B) and click into place.
5. Confirm that the triangle marks (A) on the delivery feeder unit are aligned with the triangle marks (B) on the machine.
6. Close the front cover.
Close the front cover gently holding the handle.
CAUTION
Be careful not to get your fingers caught.
7. Reconnect the power cord and turn on the main power switch.
Jun 22, 2015 | Office Equipment & Supplies
I need help in canon ir 2870 error 00001
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
NOTE: if the fixing unit circuitry has an open or a short, the code may not reset.
Confirm the fixing unit wiring and try to reset the code first, before you replace the Main Power Supply Assembly
hope it helps
Sep 24, 2012 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Asko D1796 has no power. When the main power switch is activated, there is now power being sent to the control system buttons or their LEDs. I checked the outlet and there is AC power present in the...
It is possible that the main controller unit is fault as it has failed to work if there is power to the unit. If not the main power line must be checked from the switch as a continuity test will confirm if there is any break or fault in the switch.
If not the power section of the main controller unit is faulty and in most cases this must be replaced as a full board.
Sep 27, 2011 | Asko D1796FI Built-in Dishwasher
IT Won't power up.
Possible failure of the main power supply unit which is a switch mode power supply.( SMPS).
You need to disconect the power supply to the printer and open the panel to check the SMPS unit.
Please check on the link below for tips to check the SMPS unit. If this is not possible check with a power supply unit to confirm before you order.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jul 29, 2011 | Kyocera Mita FS-C5016N Printer
JUST STOPPED WORKING NO POWER WATER STILL IN THE BOTTOM OF THE DISWASHER
Possible that the power supply unit or the main program controller unit has failed. Hence the drain pump has stoped working. You must remove the power control/program controller unit to confirm.
Jun 25, 2011 | Dishwashers
I have a problem with my 42pfl5332d/37 lcd tv. I replaced the main unit because I had a tech check out the tv and he said it was the main unit and wanted to charged me $325 to fix it. I actually have 2...
You probably have a bad T-con board. It is located (looking from the back) top center. First try to uplug it and plug it back up (reseat the plugs). I would take the T-con board out of your working tv to see for sure.
Jun 16, 2011 | Televison & Video
My whirlpool washing machine power supply not showinhg and when switched on it dost not switch on
Possible that you need to check from the main power switch. Check the power supply outlet, check the power plug to the mains wire to the washer's program controller unit. If there is power till the power supply on the washer then there is failure within the unit and needs a change. Estimate and Confirm
Feb 04, 2011 | Whirlpool Washing Machines
Carrier Aircon WCARG010EE 1 HP (remote) It seems the fan doesnt work, and the remote doesnt work. and there is an Fr that keeps blinking.
You must check if there is power to the fan to confirm if there is failure of the fan motor. Since the FR display indicates there is possibility that the power is initiating.
If the remote unit is not powered from the main unit then it is possible that the main control section must be checked for failure in the control unit.
Check for faulty wiring to the remote unit-or a break in the wiring from the main unit. Check the received voltages on the remote unit.
Dec 09, 2010 | Carrier Heating & Cooling
There is no indication that power is getting to the Microwave. There is power at the socket so I know that it is getting to the plug. It has been working fine up until yesterday during the Thanksgiving...
The power from the plug to the main unit- the board must be checked. So you will need to remove the top panel to check, disconnect power and use a multimeter to check the fuse, power to the main board.If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Nov 26, 2010 | Samsung SMH9187ST Microwave Oven
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
Saeco Magic De Luxe Espresso Machine Logo
152 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
