First thing to check is the fill tube and make sure it is not frozen with ice.some ice makers can be manually advanced in order to refill with water some have a reset button to do this if these two things do no good and the fill tube is not blocked with ice then repalce the water fill valve on the bottom rear of the unit
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
