Televison & Video Logo
Laura Natoli Posted on Oct 22, 2012
Symphonic TV has no sound unless I am playing games.
I left Wii plugged in overnight. Next day, no sound on my tv for watching shows, etc. But when I plug in my game consoles, I get sound for them so I know the sound is working. Why can't I hear it when I watch television shows?
A
Anonymous
Could be something wrong with the tuner inside of the TV.
5 Related Answers
Anonymous
  • 1476 Answers
  • Posted on Jun 23, 2006
SOURCE: atenna plug pulled out of tv, how do i get a signal now?
It has always amazed me how many "F" connectors get pulled out of tuners. I know because I've replaced hundreds, usually successfully, saving the cost of a new tuner. You need to unsolder the tuner from the board and remove the side cases. If the tuner board is not damaged beyond repair, (if it is you have to get creative), a new unit can be soldered in place. Put everything back together and you will be in buisness. New "F" connectors can be purchased from MCM Electronics at www.mcminone.com, part #215543 for $2.50. I always use a new connector as the old ones are usually trashed. Reliability is compromised if you don't use a new one. Technically you do not need the cable hookup since you have composite inputs. For my money I would just hookup a VCR (with a tuner) coming out of the VCR composite jacks into the TV composite jacks and use the tuner on the VCR leaving the TV in Aux, or whatever they call the composite inputs, and call it a day. It's you're choice but using a VCR tuner is faster, easier, cheaper and if you want to play a VHS tape you're already hooked up! If you are a traditionalist and want the TV 100% remember to be safe while working on it. Good luck whichever way you go.
Anonymous
  • 398 Answers
  • Posted on Jul 09, 2007
SOURCE: Lost Remote Control
Do a google search for "emerson remotes" (in quotes) and take your pick. I have ordered them by model number from Fox International at 800-321-6993.
salt56
TV Doctor
  • 373 Answers
  • Posted on Dec 30, 2007
SOURCE: Sanyo DS24205 24" TV input problems
I'm sure you know you need the original remote if there is no menu on the front of the set. I suggest doing a search for customer support online for Sanyo products. There you will find contact numbers to see if one is available. Try "Sanyo remotes" on Google or Yahoo etc. Hope this helps
Anonymous
  • 30 Answers
  • Posted on Oct 17, 2008
SOURCE: DS24205 TV INPUT PROBLEM
You can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Anonymous
  • 2992 Answers
  • Posted on Apr 01, 2009
SOURCE: how to get wii game to work on tv i have a sylvania tv
The Wii console should have included a cable to plug into the AV Multi-out Connector. This cable has the plug for the Wii on one end, and three RCA plugs on the other. They are color-coded yellow for the video output, and red and white for right and left channel audio outputs. These plugs would go into the corresponding RCA input jacks on your TV (if it has them), and you would select that input using the TV remote or front panel buttons.
If your TV doesn't have A/V inputs, you need to get an RF converter. This device takes the A/V signals from the Wii and converts it to a signal on channel 3 or 4 so you can tune it in on your TV. These cost around $15 at Wal-Mart and other retailers.
If you have lost your Wii connecting cable or didn't get one, you can order replacements from online vendors.
2answers
Why can't I watch Hulu on my Google TV?
Hey bud no reason to return your Google TV unless you absolutely have to watch shows from Hulu via Google TV. The loss of Hulu is definitely a bummer from this service and I know that I can't get NBC, ABC, FOX, and CBS on my device as well.
Until I tried this hack of course.
That website will run you through everything you need in order to start watching Hulu on your Google TV, but be careful because Sony doesn't like their devices being tampered with.
If I was you I'd recommend just sitting tight and watching Hulu via your XBox. No skin off your back and you stay clear of any problems a hack can bring.
4answers
I cant select games mode manually on the symphonic
I think, after you have the rca jacks inserted into the tv and to the game you're playing, youshould be able to move the channel button down past channels 3 and 2. And or hit menu on the tv and look for setup. Try that!
1helpful
No sound
Try to attach another device to the Tv to make sure it's not the RCA jack first,If sound works from the other device,You can take the WII to your local Game stop,Play n Trade,etc....Most of them do system repair.
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
No Picture or Sound
I dont think it's worth getting a repair man to come fix a Symphonic TV... honestly, they are problem prone... and It would cost much less to just buy a whole new one. I have a symphonic tv with no remote, and now, I cant switch into game mode! It's like they designed their tv's to be crappy!
WII audio and TV audio simultaneously
do you have surround sound, if you do you will need to plug the wii hookups into the surround sound, or plug it into the tv and shut the surround sound off.
Blank screen during game play
Is there another input you can try?
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
