I have a sony vaio notebook laptop, on taking out the hard drive and putting a new one in, the laptop refuses to switch on, only a green light shows under the screen, also the keyboard ribbon is bent, could this be why it doesn't start?
SOURCE: Dell Inspiron 1000 Disassembly
Dear RBROWN67,
you can find the service manual for you DELL Inspiron1000 Notebook , from these URLs:
http://support.dell.com/support/edocs/systems/ins1000/en/index.htm
http://repair4laptop.org/disassembly_dell.html
Hope these sites are helpful for you in future also.
Cheerup and Be Happy always
SOURCE: simpletech external hard drive is showing as write-protected disk
Usually a protected hard drive has been in a laptop and the hard drive password is setup from the laptop's BIOS configuration. This password is embedded on the hard drive's chip.
This password protects the data from unauthorized access and must be removed before reuse in another laptop or as an external hard drive.
There are no backdoor passwords available and needs to be removed using that laptop's BIOS configuration, you need to know the password to enable you remove the password peotection.
SOURCE: sony vaio vgn-TX750P how to open the case to swap the hard drive
here you go mate i found u this coz i know how much of a pain in the arse sony vaio's are :
http://laptoplogic.com/resources/detail.php?id=43
GOOD LUCK LADS!
SOURCE: Sony vaio laptop unable to detect new hard disk
Try connecting the drive to another pc with a usb adapter, create a partition and format it. Then put the drive back in the vaio and reinstall windows. This should fix the problem.
