Question about Kenmore Elite 45986 Front Load Washer
Control panal my panal is locked up how do I unlock it?
  • Kenmore Master
  • 19,396 Answers
Try unplugging power cord for ten minutes or removing circuit breaker to cut power and reset the appliance.
Check that water is coming from the supply at the back, and also cjheck that the drain hose is not blocked.
If the above did not solve the problem, then there is an internal fault, in that case better calling a technician.
Posted on Jan 02, 2009
"Control locked" light is on. Machine will not
Press and hold the button thats says control lock//that will unlock or lock the control panal...If it helped please vote need more help please ask good luck
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine LG Direct drive 7, 3.5kg WD 12331AD It has CL sign on it i cannot operate the machine how can i clear that nad get the machine to work?
CL means control lock should be a button or bottons on your machine that you press and HOLD to unlock the control panal...so the childern don't mess with your washer....Good luck
Feb 01, 2011 | LG Washing Machines
I have an LG frontloader washing machine, all the buttons are disabled and there's an error message "CL" on the screen. please assist.
CL is for control LOCK look at the bottons there is one that you will press a hold to lock or unlock the control////it is so no one will mess with you cycle after you start it ...childern ect.....if you can't find the botton go to manual look up locking control panal....good luck
My control panal is locked, I have tried holding the cancel button and I have tried unplugging the washer
Manually unlock the door lock system by removing the lower kick panel. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. Located on the bottom of the door switch/lock unit is a tear drop shaped tab. Gently pull the tab down about a 1/4" or until a click is heard. The door may be opened. Remember to unplug or disconnect power first.
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Power door locks
This could be hard to diagnose for someone that doesn't know about electronically controlled automotive systems . There are two electronic control modules involved ! (FEM) front electronic control module and the (REM) rear electronic control module . The first step would be to hook up a scan tool to look at input data to the control modules. Corrupt signals to the module ! B+ power an ground circuits problems . The wiring inside the harness from the body to driver door , opening an closing of the door breaks the wires over time . Load testing the circuit will find the problem.
Ford 150 Power Door Locks Diagnosis
Door Locks Go Crazy 2
Mar 29, 2017 | 2001 Ford Windstar
Craftsman Garage Door Opener Locking Feature
Press and hold the lock button down for three seconds. The light should turn solid and the unit is unlocked.
Mar 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlepool Duet Gas Drier front load Control Panal locked How do
Press and hold the end of cycle signal button for 3-5 seconds.
Mar 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I remove the inside door panel on drivers side
you need to take out the door panal and work from the inside of the panal. Open it from there.
Jan 11, 2009 | 2001 Mercury Grand Marquis
Control lock meassage come out in the screen
Its aproblem of command section.Check its components one by one.you can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem
Sep 24, 2008 | SAMTRON 55V 15" CRT Monitor
Front panal not working
tv is locked no power turns it on how to break lock
Aug 21, 2008 | RCA TruFlat 27F520T 27" TV
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
