Question about Euro-Pro Shark 80 - 7133
Birdsnest and machine jams
I was sewing on some felted sweaters and suddenly my machine stopped working. It is making huge birdsnests around the bobbin mechanism and jamming to the point where I have to cut the whole piece free from the machine. I went through whole spool of thread trying to fix it, just to give you an idea of how much it's winding up underneath. I thought it was a dirty bobbin assembly, so I took the bobbin mechanism apart, cleaned it thouroughly inside and oiled it. Still happened. If I pull the top thread while it's sewing, it will work for a few stitches until it tangles again. It seems like the upper thread tensioner doesn't work anymore, but I can't be sure of that (just a guess). If anyone has any suggestions I'd appreciate it!!
  • sassyanne Feb 19, 2008
    my euro pro model 1262d, every time i sew there is a birdsnest underneath and the machine jams up and does not sew anymore, it does it all the time.
  • 4 Answers
I have a singer 457 (from 1964!!) that I inherited from my grandmother. It worked successfully many months, but then I developed a similar problem (birds nests, tangles in the bobbin assembly).
AFter messing with the tension, different spools of thread, and what not, I found that it was the BOBBIN that was the problem. Althought this bobbin is the same size and shape as others, there is something about it that knots up the inside of the machine EVERY time (as in within 15 stitches or less).
I tossed the thing and have been trouble free ever since.
I am now convinced that bobbins (particularily plastic ones) wear out.
Posted on Jan 27, 2009
  • DivaMomCarol Aug 13, 2011
    I am so glad I read this comment. The birdnests were driving me crazy and since we are in China I was very concerned about where I would get my Janome 6600P serviced is I couldn't find an easy at-home solution. The problem was INDEED the bobbin. Bobbins have specific heights and the one I popped into my machine was NOT the proper height. Once I determined that...NO NESTS and NO more tangles. Thank-you!
Ok, this is real simple. pull the thread from the bobbin up through the bottom of the machine near the needle. also, hold the thread that you threaded through the needle with the other strand on the left of the needle. hold them there for a few stitches... and wahla! no more birds nest.
Posted on Nov 22, 2008
Try turning the thread spool around sometimes that will make a huge difference.
Posted on Jan 06, 2008
I have a singer 3321 talent. Where the bobbin sits is catching & clumping, creating a birdsnest on the back. I tried rethreading both the bobbin and the top, checked my needle, adjusted the tension.
If you haven't already, install a brand new needle. Then make sure to RAISE the presser foot before threading the upper thread.
Also check to make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues, then it probably needs service.
Mar 13, 2016 | Singer Sewing Machines
Bobbin tread bunches and jams machine
If the bobbin is inserted with the thread spinning the wrong direction this will cause "birdnesting" - thread build up under needle plate, you need to cut thread to get the item off machine. flip the bobbin over into the case and try again. Also make sure you remove ALL thread caught up in "Birdsnest" when they happen.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 27, 2014 | Singer 2263 Mechanical Sewing Machine
Birds nests embroidering husqvarna viking designer se
sounds very much like insufficient needle tension
Feb 01, 2014 | Sewing Machines
Motor stopped; locked handwheel
Remove the needles. See if the handwheel moves now. Since it's a new machine, consult with the seller.
Dec 23, 2013 | Juki MO-655 Mechanical Sewing Machine
Bobbin always jams, thread bunches up under fabric, auto winding causes a birdsnest of ruined, loose thread and most importantly it won't sew.
Your tension is not set right. The tension setting is usually around 4 and can chang e depending upon the fabric you are using. Hope this helps.
Dec 10, 2013 | Singer 2250 Tradition
Intermittent sewing problems
You have two problems:
1) Sometime it sews fine, but other times it will sew like there is no tension on the thread and create a "birdsnest" in the bobbin compartment.
Cause : Threading the upper thread
- clean upper thread tensions discs
- do not forget "• raise the needle and presser foot" (see manual page 18)
2) Sometimes it just randomly changes ...
Please open new ticket. Give tu us more info. It seems like Short circuit on S-print, but your description is chaotic (not usable)
Apr 19, 2017 | Bernina Activa 130
My futura machine keeps every few seconds and stops sewing, what the problem
this was my first problem - if youhave had a "birdsnest" you probably damaged the bobbin case - take it out and run your finger aroundthe outside edge . You will probabaly find a nick where the needle has crashed down on the bobbin case. If you can sand it smooth it may start pulling the thread around the bobbin again. Twice I have had to replace the bobbin case. It is cheap just google on the internet. Now I have a spare if anything happens. I also found if you stick to the embroidery threads and not try to use up old or cheap thread it will run more smoothly.
Dec 01, 2012 | Singer CE-100 Futura Computerized Sewing...
I have Model HF 2022 and I am trying to make a gathering stitch (a long sttich that I can pull one thread and make the material ruffle). I have tried to use the number 4 length to do this but the stitch...
It is not the stitch length, but rather the thread tension that you change to do this neat little trick. Lower your thread tension to about 1, just enough so it won't birdsnest, then try again. You also might want to try an inexpensive ruffler foot (starting at about 15 dollars) or a shirring foot (around $5). These would help making toddlers and pleats a quicker, easier, more uniform task. ;)
Jun 21, 2011 | Sewing Machines
I have a singer sewing maching model 3 57817c. I am making slipcovers, and have made several cushions already with no trouble at all. Suddenly the machine seizes up, and I can only procede by manually...
Is this machine older and has it been serviced recently? What weight fabric are the slipcovers made from. Domestic sewing machines will struggle with really heavy upholstery fabric, the feed dogs struggle to get two layers through smoothly. You can try to hold the fabric firmly front and back and guide it through but often four or even 6 layers when crossing seams will just be too much. You can try using a "humpjumper", http://www.punchwithjudy.com.au/shop/the-hump-jumper.html a little plastic bit that you hold under the foot at the back while stiching into a thick seam, it does help.
Does it need a good clean out in the tension and bobbin area? If it hasn't been done for a while break out the manual and give it a good clean out firstly, particularly the rotary hook and then give it an oil as per manual.
The jamming up sounds like tension issues, if you are getting a birdsnest on the bottom then top tension is the problem - check thread is going through the tension discs, turn it back to 5, lower the pressure foot and pull the top thread from just above the needle - it should be firm to pull. Also, if you can access them, turn tension dial to zero and "floss" between disc with the selvage edge of a clean piece of cotton fabric to remove any dye buildup/lint from the discs. You can also dampen the fabric with a bit of denatured alcohol or similar to help clean them.
Also did you change needles after sewing Velcro, it is very hard on the needle and would take the edge off it straight away. I use blue jean needles for velcro, even if the fabric isn't denim, the blue coating helps the needle get through the velcro, also, just sew in the margin where the hooks aren't around the velcro and go real slowly, I use the needle up/down button to get around the corners carefully for this.
So, good clean, oil, new needle, then set tensions back to normal setting and test sew on some fabric scraps. If its still mishaving then its possible that the timing is slightly off, take off the thread, remove the needle plate, and turn the flywheel manually while watching/listening as the hook goes around, does it pass behind the needle when the needle is at the lowest point? Sometimes timing might just be slightly out - probably best for a technician to address though which isn't going to help you get the slipcovers finished.
May 11, 2011 | Singer Sewing Machines
Spool is bouncing on spool pin
Get a stand alone spool holder, sometimes the spool pins arent high enough to support the thread or you can try a thread sock
Jul 16, 2009 | White Sewing Mighty Mender WW100...
Euro-Pro Shark 80 - 7133 Logo
1,137 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
