Question about Compaq Keyboard
Can you please help how to remove r4200 compaq laptop keyboard? I will replace the ram
    Problem Solver:
  • 7 Answers
You shouldn't need to remove the keyboard. there shouls be an access port on the bottom to remove with a screw driver.
Posted on Jan 02, 2009
How to remove RAM from compaq presario v3000?
1. Identify where RAM resides:
- On the front (you will either need to access the RAM memory by removing the front parts of the laptop (Keyboard, Touchpad etc)
- On the back ( usually a RAM memory door to unscrew)
2. After accessing RAM sockets, hold both metal prongs to the side. The RAM memory card will release from the motherboard.
3. Gently hold the ram card on a 45-degree angle and remove the card.
4. Install your new replacement RAM memory.
May 14, 2014 | HP Pavilion dv6000z Notebook
How can i get to both memory slots so i can upgrade to 2GB of Ram? Thanks
Your laptop has two memory slots. One of the memory slots (external) can be easily accessed if you remove the cover on the bottom of the laptop.
The second (internal) memory slot is located under the keyboard.
Keyboard removal procedure:
1. Unplug the AC adapter and remove the battery.
2. Remove two screws securing the keyboard on the bottom of the laptop. These screws are marked with a small keyboard symbol.
3. Release 4 keyboard retention tabs located on the left side from f1, f5, f9 and delete keys.
4. Lift up the keyboard and place it upside down on the palm rest.
5. Unlock the keyboard cable connector on the motherboard.
6. Remove and replace the keyboard.
Hope this helps. Thank you for using FixYa.
Sep 30, 2010 | HP Compaq nx8220 Notebook
How to replace/upgrade RAM on HP/Compaq nx5000 laptop? HP's quick reference guide says the slots are under the keyboard deck? How do I get there? Thanks
to remove the keyboard u will 1st need to undo the screws that hold it to the board should be the 2 or poss 4 directly unde the corners of keyboard other than that the covering panel at top of laptop will need removed 1 screw either side underneath screen hinges and poss few small 1s where battery slots in once cover removed the keyboard will be held on with 2 screws at top and the cable remove both and viola
Jan 16, 2010 | HP Compaq nx5000 Notebook
System unit error in pentium 3 compaq presario
304 error reffers to keyboard error. Verify if your keyborad is properly plugged in, also verify if it's working (pressing Num Lock will turn on the led, pressing again will turn off).
If you plugged in an USB keyboard it won't work, it is necessary to be present an PS/2 keyboard.
Sep 02, 2009 | R.A.M. Computers Compaq Presario 1075,...
Replacing the keyboard on a compaq presario v3000
Here is a link to the Service Guide for the v3000z. The information regarding removal of keyboard starts in section 5.10 page 5-21.
Hope this helps. Please remember to rate this information.
Thanks
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
I'm upgrading Ram Compaq R3200 laptop
Found my solution. Was under keyboard. Required opening laptop as far as possible, removing 3 screws from the back that hold the piece of plastic just above the keyboard. With flathead screwdriver lift the right corner of the plastic piece then, with the same screwdriver lift the top center of the plastic piece to remove the piece entirely. Unscrew the 4 screws that hold the keyboard (across the top) and lay they keyboard forward (toward you). THERE is the Ram.
May 22, 2008 | HP Pavilion ZV5000 ZX5000 Compaq R3000t...
Removal of laptop keyboard
Dear ctmom
Please find below the link to download the
HP Pavilion zx5000 Notebook PC, HP Pavilion zv5000 Notebook PC, Compaq Presario R3000 Notebook PC, HP Compaq nx9100 Notebook PC - Maintenance and Service Guide
( http://h10032.www1.hp.com/ctg/Manual/c00212209.pdf )
Removing the keyboard firstly requires the removal of the top plastic strip in order to gain access with the screwdriver to the four screws. To remove it follow the instructions at pages 137 & 138 and you are almost there.
Then on page 139&140 you will find the information to remove the keyboard. It explains all the information very analytically. You are simply unscrewing the four screws on the top side. On the bottom it is simply slided.
TIP: Be careful when you are releasing the keyboard up towards you. The flexi cable that is connected to the motherboard is quite short-fragile and does not have a lot of space to move so go slow until you have released the connector’s tabs and the cable is loose to be removed.
Please remember to remove the battery before you do any work in the laptop.
Mar 17, 2008 | HP Compaq Presario R4000 Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Compaq Keyboard Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
