No pwr to motherboard when 4 pin socket connected.
When the 4 pin isnt connected the fans spin, the hdd's spin but no power to monitor at n e time. no beeps at start, no bios screen showing at n e time. n e thoughts?
  • 416 Answers
If it's under warranty, i suggest you take it back to the shop, looks to me you have a factory defect MB.
Posted on Jan 02, 2009
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
Woule like the pin location for power & leds on F-P1 socket
The corner of the motherboard "diagonally-opposite" of the keyboard/mouse PS/2-port connectors has a grid of gold pins. One pair of pins is labelled 'PWR'.
One pair of pins is labelled 'RST SW' ("Reset Switch").
Another pair of pins is labelled 'PWR LED'.
Another pair of pins is labelled 'HDD LED'.
Jan 10, 2011 | Computers & Internet
Asus M4A785-M will not post. I have completely removed motherboard from case, removed all components except CPU (AMD Phenom II X4) and CPU cooling fan. When power supply (which I tested in seperate...
All I read properly .Please remove power supply from HDD and CD /DVD RW. If you face the same problem Open the mother board on a open place and try it again ,because there are some particles witch has made the short sercit in your M. Board.Cgeack all voldage socket plkaced properly,MAY BE CAN SILLY MISTAKE FOR 4 pin socket .
If you face same problem please install in another mother board .Post me please imediate next result.
Dec 12, 2010 | ASUS M4A785M (890552666775) Motherboard
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
Jul 27, 2009 | Dell (E210882) Motherboard
Nothing happens when I press the power button. No
What about the power supply? I bet it's supply's issue. Otherwise make sure that PWR button wires are connected properly and to the correct terminals of the motherboard
Jun 29, 2009 | Intel D915GAG Socket 775 Motherboard -...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Two sets of power leads to motherboard from pwr pk, 1 x 20 pin and a 4 pin, when the 4 pin isn't attached to the 8s651mp-rz motherboard the fans spin, the mother board light comes on, but then does...
The 4 pin connector is required as it provides the power for the CPU to run. if nothing is happening with the 4 pin connector plugged in then there is a problem. You need to make sure that you Power Supply can supply enough power for what you are connecting to it (400W would be the bare minimum with no high end video card, 500W would be recommended). You also need to make sure that the Power Supply is connected properly because some Power Supplies from pre-built systems from companies like Dell are wired differently than the standard power supplies. The only other likely problem is that there is a short on the motherboard either from the mounting of the motherboard in the case or from something on the motherboard being bad. Make sure there is no metal touching the motherboard except at the holes used for mounting.
Jan 02, 2009 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Computers & Internet Logo
418 people viewed this question
David Payne
David Payne
