The webacam will not work on the notebook (Acer Aspire 5630). The orbicam.exe file will not execute and an error message shows there was an app crash.
SOURCE: Acer orbicam not working
what you can do is... have your My Picture folder empty... and just create a new folder in the documents folder. saying as "pic" or wat ever... and transfer everything there and when you save any pictures off the internet or something dont save it in my pictures.. i tried that and its working perfectly fine for me... i hope it works for you as well
SOURCE: acer orbicam- aspire 3680
Whenever it displays this try and reboot your system and if the problem persist, then t to reinstall the driver for the orbicam. good luckk
SOURCE: acer aspire orbicam stopped working
I have a notebook Acer Model Aspire 5601 AWLMi. Incorporated Webcam did not function anymore after I installed again Windows XP. I downloaded also the driver from Acer driver but without any result. It seems tha acer givs only external webcam drivers for the 5600 series.
SOURCE: Pioneer DVR-K17RS ATA ACER CODE=39
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
