Our alpine air con works but its not cold what could it be
  • Stephen Evans May 11, 2010
    do you know if the compressor is running?
  • 334 Answers
Low refridgerant or dirty coils/filter.
Thats pretty much the only thing that will cause an AC to not cool if all the other mechanical components are working.
Check/change the filter.
Clean the coils/ have them cleaned.
And have the refridgerant levels checked.
Posted on Jan 03, 2009
Cruze - hot air from driver side and cold from passenger
Do yourself a favor an take it to repair shop before you mess it up or hurt yourself !
May 14, 2015 | Cars & Trucks
Ac fan works but does not get cold
Check the air con drive belt is still OK.
Check to see if there is a slight change in the engine sound when the air con is switched on and off while idling - I'd get someone to do the switching while I listened under the hood.
If there's no change in sound (assuming whatever had to be switched on to enable air con to go, eg fan was operating) I'd check the fuse(s) for the air con.
If the fuse is ok, and you've already charged up the freon (not quite sure what you were saying there), I'd be taking it to an air con specialist.
May 26, 2014 | 1995 Buick Century
Air con working but only cold air coming out
Isn't cold air what you want from the AC??
Mar 28, 2014 | 2000 Daewoo Leganza
I HAVE A AN ISSUE WITH PORTABLE AC IT DOESN'T BLOW COOL AIR
dear sir
please make sure first your air con,s compressor is working if it, working and it,s not getting cold then it can be low gas problem or if compressor is not working then please check the thermostat settings and make tempreture correct and setting on cool mode
then i hope if it,s only normal problem then your air con will work again .
after that if not get cold then contact to air con technician for repair it (it,s need to repair and only air con special maintenance person can do it)
thank you
hope answer the question
please vote!
Sep 24, 2010 | Amcor A12000E Nanomax Portable Air...
Audi A3 2tdi 2005 - hot air, cold air and air con not working -
You may need to reset basic settings for the control module using a scan tool , reading the logged faults stored in the control module is needeed also .
Jun 24, 2010 | 2005 Audi A3
Nissan xterra..2000
your air con needs re gasing
Jul 07, 2009 | 2000 Nissan Xterra
My blower only works on setting 123 + air con not that cold
You have a resistor array assembly going out. What you described is typical of the first resistor going out and over loading the second, which goes out and overloads the third. Replace the HVAC resistor array. Don't buy a used one. Spend the extra money on the new OEM dealer item. Good luck to you.
Apr 20, 2009 | 2000 Jeep Cherokee
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
