Question about HP LaserJet 1100 Printer
HP LaserJet 1100
Printer whines when printing anything.
  • Rich Lichvar May 29, 2007
    Here's the quote directly from the user:
    "It makes the sound while the paper is running through, however, after the paper has fed through completely and the printer is winding down, you can usually hear something that sounds like gears grinding inside the printer."
    Many thanks for the help!
    Most of the time when I've looked at the cost to repair vs. the cost of a new "personal" laser printer, the difference is so small that, especially if the printer is out of warranty, you might as well buy a new printer.
    Many thanks for the help/information!!!
    Rich
  • 40 Answers
Does it only whine when it paper is passing through it? Does it whine before the paper is fed in and after it's ejected? If so, could possible be the fuser unit. If it only whines when paper is passing through, it may be the paper passing between a worn-out feed roller and separator pad, which are high-mortality items on this model. Can you supply any more details?
Posted on May 29, 2007
  • Chris Yost
    Chris Yost May 29, 2007
    Sounds like the issue is with the paper feed mechanism. Unfortunately, that's something that would need to be addressed by am HP authorized technician (like me).
    Compare the cost of parts and service against replacing the printer. It's a good personal printer, but it's also in the neighborhood of 6-7 years old. Food for thought if nothing else.
    Let me know how it turns out!
Hp laser jet 1100 printer cannot print a document?
Refer the below link if hp laser jet 1100 printer cannot print a document
http://tinyurl.com/mrajesh171
Jan 03, 2011 | HP LaserJet 1100 Printer
Driver installed, does not print!
did u get a test print when u installed it....
do u c the printer hardware installed in the Control Panel/Printers and Faxes/
if yes then check to see if that printer is the default printer selected (a tickmak will appear in front of that)
else uninstall the printer from the Control Panel and re-install
Dec 17, 2009 | HP LaserJet 1100 Printer
My HP 1100 won't print after power outage during printing
Not worth it to fix. You can find 1100's on ebay for $30.
Mar 02, 2009 | HP LaserJet 1100 Printer
HP laserjet 1100 won't print from Vista laptop
Which version of QuickBooks are you using? Anything older than 2008 will not work with vista.
Jul 08, 2008 | HP LaserJet 1100 Printer
Continuous garbage text when connected to pc
In reading this HP forum I have found many other LaserJet 1100 owners who are trying to do the same thing as you.
Many of them recommend various cable solutions from Sewell. When you contact Sewell, make sure to specify your printer model, and ask what specific cables and/or adapters you need to make it work vis USB. They sound quite knowledgeable, and seem to have dealth with this before.
Mar 06, 2008 | HP LaserJet 1100 Printer
HP1100
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
Jan 15, 2008 | D-Link DP-G321 Print Server
HP Laserjet 1100
Had the same problem with my HP 1100 printer. It was a faulty laser unit. Replaced the laser unit and the printer was fine.
Nov 08, 2007 | HP LaserJet 1100 Printer
HP LASERJET 1100 WONT PRINT
go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
Aug 14, 2007 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
