Question about LG LD40E Dehumidifier
I live in ohio and my LG dehumidifier had ice on the front completely covering the grill openings on the top. I unpluged it and let it all melt. Is there someing I need to look for or do before pluging back in?
SOURCE: Really thick ice on back of dehumidifier
It is now frozen because the humidistat, which controls the on/off cycle, is starting to age and forgetting to turn off the dehumidifier. Try removing the humidistat and, using compressed air, blow it out thoroughly of any dust. Then spray the rotary control area, including electrical parts, with WD-40. Then, blow dry again with the compressor and try again.
Posted on Jun 24, 2007
SOURCE: Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
SOURCE: LG dehumidifier developing ice
First you would need to clean the filter. LG recommends cleaning the filter every 2 weeks on their dehumidifiers. The second thing you need to do is clean the coils periodically. On this dehumidifier it should include a brush for cleaning the coils. It is located on the top of the bucket. To access the coils the following needs to be done:
1.) Unplug the unit from power
2.) Remove the bucket and also the air filter
3.) Remove the front pannel by removing the 2 lower screws and depressing the tabs.
4.) Once the panel is removed you will see the coils. You need to clean them with the brush. Go in an up and down motion to remove the dirt and dust.
Now use the reverse steps to put it back together. If your dehumidifier runs often I recommend you clean the coils about every 3 to 4 months. This is a common problem on alot of dehumidifiers and people think their dehumidifier is broken. Most of the time the coils are just dirty which causes the water to stay between them and freeze. Keep me posted. Also if you found this response helpful, please rate this solution when you get a chance. Thanks - Tech101
Posted on Jul 03, 2008
SOURCE: LG LHD45EL Dehumidifier Icing Over
The only thing you need to replace would be the temp control it sounds faulty hope this helps :).I had the same problem with mine and that is what went wrong.
Posted on May 16, 2009
SOURCE: Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
Posted on May 17, 2009
Sep 18, 2011 | LG DH404E Dehumidifier
Jul 24, 2011 | LG DH504E GoldStar Dehumidifier
Mar 01, 2011 | LG LHD45EL Dehumidifier
Jan 27, 2011 | LG LHD459EL Dehumidifier
Sep 03, 2010 | LG LHD45EL Dehumidifier
Aug 17, 2010 | LG LHD45EL Dehumidifier
Dec 25, 2009 | LG LHD65EBL Dehumidifier
May 16, 2009 | LG LHD45EL Dehumidifier
Jul 24, 2008 | LG Goldstar LD65EL Dehumidifier
Jun 23, 2007 | DeLonghi DDE50E Dehumidifier
Apr 17, 2018 | Dehumidifiers
345 people viewed this question
