Question about Hitachi Televison & Video
"Hitachi Remote control doesn't have a code for DTV HR20 Receiver
I can't control the TV with the Directv remote because the Hitachi 50VS810 requires two steps to change "input", you role down to the input you want and then hit "Enter". If I could use the tv remote to control the satellite box, that would be ok, but it doesn't have a code for the HR 20 receiver. Hitachi was no help when I asked if they had a newer remote that would have a code for the HR20 and also operate the tv set.
Any ideas?
  • Hitachi Master
  • 19,396 Answers
The codes for this model had not been made available, therefore, the only way to synch the remote with tv is by auto find, that is a tedious procedure, and does not always work.
An alternative solution is buying a replacement remote for the tv, see: Hitachi 50VS810 Replacement Remote Control
Posted on Jan 02, 2009
How to Access Directv Apps?
DIRECTV TV Apps are FREE and easy to use. Just press the
right arrow button on your remote to launch the TV Apps dock,
select the app you want, and enjoy! TV Apps require a
broadband-connected HD or HD DVR receiver (models H21 and
higher, models HR20 and higher, and models C31 and higher).
Oct 19, 2016 | Televison & Video
Remote codes
the 4220 does have SAT code 1377 on board, and will work with the following Directv sat receiver models: D10, D11, R15, H10, H20, and HR20.
Try code: SAT1377
What address is the D10 set to, DTV (00001) or AV1/AV2 (00002)? SAT code 1377 is for receivers set to white remote native code 00001.
to blink back the code on the white remote:
1. dtv
2. press and hold MUTE & SELECT for two blinks
3. enter 9-9-0
4. press #1 key, it won't blink because the numeral is zero
5. press #2 key, same as a above, zero blinks
6. press #3 key, zero blinks
7, press #4 key, zero blinks
8. press #5 key, this should be 1 or 2 or 3 blinks
Mar 31, 2010 | One For All URC4220 Remote Control
Universal remote control CODE for starsat receiver 150D
i have star sat remote sr x5100 plus. i want code to buy a new remote control
Apr 09, 2009 | RCA DRD430RG DirecTV DTV Receiver
Hitachi 50sv810 Remote
Now I have got the problem clear, depending on the TV model there can be no way to have this HR20 functionality on your TV.
Universal remote may not have full functionality on HR20 .
The TV remote should have a function to select the input on TV, this is often called AV selector, or on some old model it is activated by pressing the 0 button, check this out and let me know.
Jan 02, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Hi, sorry I confused things on my first post, I understood now that you need a remote to operate the HR 20 , as TV has his own remote.
If you have original remotes for TV and HR20, you should be able to do the job, and that would be best solution.
If instead you want to use an universal remote, the only way out is using auto programming on universal remote, as HR20 codes are not available.
Auto find or auto programming mode is a feature of all universal remotes, you need to check universal remote manual, and follow the procedure, untill this operates your hr20.
Direct TV HD Receiver/Recorder codes
Check the Innovage manual for the automatic code search. If it works, you still may not have full control of your HR20. Try to program your Directv remote to operate your components
Jul 07, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Remote for DirecTV wont control my Toshiba VCR/DVD combo unit
Its true sorry but there isnt any codes available for combos.
Feb 19, 2008 | Directv D10 DTV Receiver
Remote control code
Those 2 remotes are not compatible with the newer directv receivers
Feb 09, 2008 | Directv D10 DTV Receiver
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
