Question about Kenmore Kitchen Ranges
Kenmore gas range flashing F3 and beeping
Model # 79075768002 where do I locate the wiring harness and the sensor unit?
  • 198 Answers
The sensor for this range is located inside the oven near the broil element. You will have to take the back off to get to the wiring.
Posted on Jan 09, 2009
My gas stove beeps and displays F3 what is wrong.it is a kenmore 970-568212
This range was made by Frigidaire for Kenmore. Thus the F3 error could mean a problem with the temperature sensor, the EOC (electronic oven control) or the wiring between the two. You'll need to get to the back of the range and check the resistance at the sensor. In a ~70 degree F environment, the sensor should have a resistance of ~1100 Ohms. (The sensor is connected to the EOC by a pair of violet wires.) Make sure to rule out a problem with the wires, if the resistance tests out of specifications.
If the sensor gives the correct resistance and the wires are fine, replace the EOC. Please check that you have given the full model number, I can't find this model anywhere at Sears Parts Direct or elsewhere.
If the stove is under warranty, contact Sears for repairs. I hope this helps.
Aug 29, 2015 | Kenmore Sears Stove Grate Replacement Gas...
F3 error. Beeping wont stop.
Hi miketack,
If your Dacor is getting an F3 error code and wont stop beeping this is because of shorted oven temperature sensor or RTD. You can fix this by checking sensor harness and harness connection between oven sensor and oven control. In case that wiring is ok you need to replace oven temperature sensor (RTD). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 21, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven goes out ,display flashes --F3-
Hi jstpchy1953,
F3 code error means open oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Oct 24, 2010 | Tappan TGF320 Gas Kitchen Range
I have a GE space maker xl1400 model 1410bc001 it is beeping & displays F3 or F4 what does the F3 or F4 mean
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 02, 2010 | Kitchen Ranges
F-3 flashes and oven beeps on front screen - what's problem? Oven will not remain on and won't let me reset oven.
F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 12, 2010 | Jenn-Air SVE47100 Slide-In Electric...
What does F3 mean when the oven is on. After preheating it starts beeping and then F3 pops up
F3
or
Sep 06, 2010 | GE Spectra JBP78 Electric Kitchen Range
Have a Kenmore gas oven. About midway thru bake cycle it flashes an F3 and beeps
F3 is a bad temperature sensor. Look in the top left or right of the oven for a short thin round metal piece sticking out of the back of the oven. Turn off the power to the range. Remove the screws,carefully pull the wires out through the front. Replace it with a new temp sensor and bake away.
Sep 26, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
JENN-AIR MODEL D156B Electric oven
Hi Sadirrd
Your problem (flashing F3) is most likely a defective temperature sensor.It may also be due to a open in the wiring harness connected to the sensor - unlikely but could be.
Post a rating for this solution
Regards
Nov 07, 2008 | Cooktops
Unlock my Tappan Gas Over Door?
Hi wewada,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Aug 03, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Millenia Range
Hi ChrisNess,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. If wiring is ok, replace the oven temperature sensor (RTD)
Hope this helps.
Jun 24, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
112 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
