Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
I have a hotpoint wd640 and i cant get it out of test mode any ideas?
  • miltmerm Jan 11, 2009
    Exactly the same problem here!
    Can't exit test mode.. Will report any solution!
  • Len Cremin Apr 29, 2009
    cant get rid of "test" indicated on digital display screen on wd640 washer!!
Trn main dial to empty drum icon
press start/cancel button and on/off button together then switch off at mains and leave for 10 mins
got this info off hotpoint themselves and it works for me
Posted on Jan 15, 2009
SOURCE:
The washer comes up "TEST" instead of the
Hello & Welcome to FixYa
Someone accidentally put it into TEST mode and to get it out of the test mode follow this:-- Unplug the washer for 4 minutes and then plug it back and press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Hotpoint Aquarius WD640 Front Load...
I have somehow managed to put my hotpoint aquarius into test mode
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Mar 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Test light is on on my hotpoint wd640 washer dryer
To get the unit out of test mode , Press the start button, press the start button again.Press the on/off button and start button at the same time and hold until display says off or end
Nov 05, 2009 | Washing Machines
Wd640 stuck on test
hold both buttons in until dsiplay clears
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f 18 on hotpoint wd640 ? any idea Everything seems to be working except drium isn ot turning, i hace checked the obvious like the belt.
F18 usually indicates a communication error according to Hotpoints error code list, if you have tried everything that you can and it still does not work, then you are going to have to call an engineer.
Dec 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpont washer/drier
if you accidently push the on/off and start buttons together, this put the appliance into a test/demo mode. to cancel it you just need to push the on/off and start buttons at the same time and "d off" should be displayed on the screen and it should now work as normal
May 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Washer Dryer
I had a similar experience.  I had to try a few times - it has to be EXACTLY together and then the magic "doff" shall appear and save the world.
Dec 19, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message "test"
yhe washing machine has been put into test mode to get out of this mode you must press and hold down the On/Off and Start/Cancel buttons until "d off" is displayed that will get you out of the test mode
Jun 24, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
182 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
