Question about Nintendo Wii Console
Trouble synching new Wii Fit
I went through the procedure in the manual and thought I had been successful in following the instructions because now the Wii Fit logo shows up where the Disc Channel logo used to be. Unfortunately though, when I try to play, the screen put up a diagram and asks me to sync the board with the console (which I thoght had already succeeded in doing) but when I try to sync it again, there is no light on the board and nothing happens.
  • 916 Answers
This must be done with each wii fit compatible game disk.
This procedure can be completed only if a compatible Game Disc is running in the console.
  • Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  • Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  • Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
  • Remove the Battery Cover on the bottom of the Wii Balance Board.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  • Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
  • Posted on Jan 02, 2009
    • 19,396 Answers
    Unplug the Wii from TV and from power, wait ten minutes and restart board synch procedure.
    Ensure there is no obstacle between the Wii and the board, as this can affect the wireless sygnal and cause device not synching.
    If the problem persist let us know, so that we can provide more help.
    Whilst using the wii to go online my son said the wii remote just stopped working so thinking the batteries were low he put it back on the docking station & left it to charge up. Yesterday when I went...
    Try buying a new remote.or press the sync button on the wii console for 15-20 seconds then resync all controllers in the wii one by one.hope this helps Julie Dentith. :)
    Apr 15, 2011 | Nintendo Wii Console
    How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
    follow this
    1. Insert a Wii Balance Board compatible game disc in the Wii console.
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    4. Remove the Battery Cover on the bottom of the Wii Balance Board.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the syncronization is complete.
    Jul 20, 2010 | Nintendo Video Game Consoles & Games
    Units will not stay synchronised
    Fiend your solution direct from nintendo. Here is your solution....
    http://www.nintendo.com/wiiconsole/prob676ijt65/solution
    jeonatumi4
    Jan 03, 2010 | Nintendo Wii Console
    Wii fit board won't work
    Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
    The exact procedure is:
    • Even if the battery level is strong, try the following:
    Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
    Try these steps!
    1 Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    a With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    d When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
    Hope it helped.
    Nov 24, 2009 | Nintendo Wii Fit - Balance Board + Game...
    Unable to synchronise wi fit board
    that somtimes happens if you want it to synch press the synch button on the wii and the balance board for about 5-10 secs then once there synched press (A) on the wii controller and theat should do it thats how i got mine to work Hope this helped :)
    Aug 29, 2009 | Nintendo Wii Fit for Wii
    Wii Fit Board won't register with Wii Fit software
    Nintendo had me set and reset the console and then the Wii fit board. They also had me take out the batteries from the Wii fit board, and repeat the reset. Apparently this works in many cases. IT didn't work for me, so now I'm bringing the unit in for repair. I am just a week past my 90 day warranty- they are charging me 47 bucks to fix it! What a sham! that's half the cost of what I paid for the darn thing!
    Jan 04, 2009 | Nintendo Wii Fit for Wii
    Synching wii fit causes wii console to no longer power up
    1, Turn off and unplug your wii console for a few minutes
    2,Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
    * Then remove the battery cover from the wii remote, inside you will see another red button.
    * Press and release the red button, the blue lights on the remote will start blinking.
    * Quickly press and release the red sync button on the wii console.
    * The remote will stop blinking and it should now be synced.
    then try syncing your wii fit bored
    Dec 28, 2008 | Nintendo Wii Console
    Re-synching remotes
    http://www.youtube.com/watch?v=-Xr71sWVacI
    May 01, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
