Question about Dell 1450 (D1450U) Wireless Adapter
When I attempt to connect to internet Explorer states 'Internet Explorer cannot display the webpage'. The machine is a Vaio PC with inbuilt wi-fi. It detects a strong wi-fi signal. Other computers in the house are working notmally.
Be sure that the work off line in tools is not activated, click on tools then scroll down and check,if ticked then uncheck. That may assist.
Posted on Aug 07, 2009
Describe your 7" G-Netbook
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
Jul 28, 2011 | Sylvania G-Netbook
My Toshiba r15-s822 isn't connecting to a wireless network and the router I already installed the router to my pc even connected an internet cable to it but Internet Explorer wont open it keeps...
Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet.
If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
Jul 02, 2011 | Toshiba Satellite R15-S822 Tablet PC
My sony vaio e series can't connect to the
You need to make some tests first,
Try to get LAN cable form other PC at home, and plug it in the sony vaio
You need to enable wireless ( Through wi fi switch, of Fn + F2 )
Please tell us your results
Good Luck
May 13, 2011 | Sony Computers & Internet
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Mar 14, 2011 | Apple iTunes
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
Hope this helps. Please rate my response.
Have a good day
Dec 29, 2010 | Opera Software Mini
Cannot connect explorer to the internet. my wireless says connected, but page keeps stating, "internet explorer cannot display the webpage"
Have you tried typing into the address bar.
I have had this problem when connecting a new PC. It is usually set to log onto MSN and this has caused me problems.
Also try control panel / internet options / connections / lan settings. and making sure the automatically detect settings is ticked
Aug 15, 2010 | Computers & Internet
it seems like your laptop not have inbuilt wi-fi connection, so you can not use the wi-fi but if you buy a USB wireless adapter or wi-fi pcmcia card so you can use the wi-fi in your laptop.
Thank you for using Fixya
Jun 13, 2010 | Compaq Armada E500 Notebook
Samsung sch-i730 cant access wi-fi
To acces the internet have you tried:
For Wi-Fi:
Tap red bar to switch from Wi-Fi Disable to Wi-Fi Enabled.
Apr 10, 2009 | Samsung SCH-i730 Pocket PC
On my PDA MC70 it is showing WI-FI "unavailable"
This can get kind of complicated, and your wireless carrier may block this depending on the data plan. It's also different for the MC7095 (CDMA) and MC7094 (GSM/GPRS) models. You may also want to see if your device BSP release is up-to-date.
Here is some basic info for the MC7095 (Sprint):
Device was not connected to network to start.
Went to Start, Programs, Internet Sharing, tapped Connect, showed Status: Check USB connection. Internet Sharing drivers were installed on laptop computer, then device displayed Internet Sharing Status "Connected". We were able to browse the web on the laptop computer. Closed out of Internet Sharing (tap X on upper right hand corner). On device, tapped Start, Internet Explorer, attempted to browse to a webpage. Able to browse on both laptop computer and MC7095 device.
Note: Attempted to Disconnect the Internet Sharing session, unable to. The device does not appear to respond to the "Disconnect" option on bottom left of screen. When tapping "Disconnect" the option light up as if being tapped however the device itself shows no other changes and Status still displays :Connected.
***FYI*** In testing with a different MC7095 (BSP33) we experienced the same issues with not being able to "Disconnect" the Internet Sharing session.
Jan 29, 2009 | Symbol MC70
You will not believe me but I have a similar problem. I have also Belkin router at home and wireless connection with my e800 works perfect. A few days ago I have tried to connect my PDA to wireless router of my best friend. His wireless network is protected like mine and after configuration of all settings I had no success. The funny thing is that PDA show me the status CONNECTED but I can not use the internet explorer. Like I said, at home with my Belkin it works properly. I can really not explain what the problem is.
Sep 08, 2005 | Toshiba e740 Pocket PC
Dell 1450 (D1450U) Wireless Adapter Logo
143 people viewed this question
Alun Cox
