Question about Olympus FE-230 Digital Camera
Olympus FE-230 won't power up properly
Olympus FE-230 zoom will not extend when turned on, attempts it a few times then shuts down, lens appears slighty off center, is this repairable?
    Problem Solver:
  • 14 Answers
It is repairable. First, check to see if it is still under warranty, (I'm pretty sure Olympus's warranty is one year) or if you purchased an additional coverage, even better. If this is the case, call it in. If not, it will not be worth the $ to repair. Unfortunately it cost as much or close to the price of a new camera to repair them and typically is not worth it. If you want to check around though, you can call some camera stores (Wolf Camera is a good choice if you have one locally). Hope this helps!
Posted on Jan 06, 2009
I have an olympus Fe-230 and when I try to turn it on the lens goes in and out several times before just closing. Is there any way to fix this?
If you have tried running the camera on Brand New Duracell, or Energizer or equal batteries with a Full and complete charge, and the camera tells you to turn it off, or simply as you say, Shuts down, then consider the following.
High Risk Solution.
This may or may not work, but it has worked for me twice on two different cameras.
The problem you have originates from the lens being bumped when the camera is on, and the gears that extend the lens skipping over a few teeth.
To set it back, watch your lens as it move in and out. Notice which way each of the barrels (levels) of the lens turns while it moves out.
Since the lens cannnot extend to it's full functioning position, (Because the gears are missaligned), it will require a little help. While it is extending, assist the barrel as it moves outwards with a small force turning the barrel in the direction it is moving while it is extending.
A click or two will tell you the gears have jumped a tooth or two, and the lens may be able to extend to it's proper postion.
Turn the camera off and on again to see if there is any difference. Perhaps repeat this several times.
Be VERRY Carefull about this and Use it Only as a Last Resort. Rely first on your warrantee if you have one, and second on your cash, if you can take it to a repair shop where they can do this.
With Great Caution, I hope this helps.
Dec 11, 2009 | Olympus FE-170 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 04, 2009 | Olympus FE-230 Digital Camera
When I power on, the lens keeps going in and out repeatedly
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
http://www.olympusamerica.com/cpg_section/cpg_servicerepair_warrantyinfo.asp
Nov 26, 2008 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
FE-230 Failure to come on
Hi Gary
Is the camera under warranty and registered with Olympus? If not registered, make sure you do that online first. It also extends your warranty to 13 months. If no receipt, It was a gift.
You most likely have a bad lens assembly (was it dropped?) or microprocessor. Here's your link...
Olympususamerica.com
Consumer division, customer service 1-800-622-6372 M-F 8 to 7 EST
Outstanding people to deal with
Hope I could be of some help. Regards, Paul
Aug 16, 2008 | Olympus FE-230 Digital Camera
I need help with my FE-230's focusing
in any case where the lens makes a grinding noise, something is in the channel and causing the lens to not extend all the way... you will need to send to a repair shop
Jul 31, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Logo
122 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
