Question about Konica Minolta DiMAGE S414 Digital Camera
Camera not switching on
Replacing the batteries with fresh one's do not solve the problem. Putting the camera on Auto has no reaction. the lense does not extend neither does the display lid up. I have tried various types of batteries including rechargeables all have the same net result. The does not switch on - no reaction what so ever.
    Genius:
  • 2,985 Answers
Take batteries out . Find a pencil with an eraser on the end, and with the eraser 'polish' the contacts at the base of the compartment. Also the contact strip in the lid. If this model takes 2 AA batteries find a piece aluminium foil to 'pack' the lid out. If it takes 4 batteries make sure two pieces of foil across each contact. Replace batteries -give it a whirl If no joy press the battery compartment lid in firmly an try. Still in trouble Then this is a more serious job for a repair shop However do get on to the Technical Support at Konica[Now Sony I believe] to see if any other remedy is available.
Posted on Jun 06, 2007
Pentax K2000 DSLR stopped working after using manual K-mount lenses?
Have a look on Pentax Forums as a guest - you may find something there
Oct 17, 2017 | Pentax Cameras
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
When turning on the camera the lense comes out and then goes right back in. New battery and memory card
Hi! Try putting your camera down on flat surface with lens facing up. Look at the outer ring of your lens and locate the small round lens located at 11 o'clock. Clean this with a que tip and see if solves your problem. This little lens works with cameras auto focus and if dirty will cause your problem. Good luck!
Sep 27, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
My camera turn off because the batery its over but it turn of whit the lens opend and now dont turn on again
When it happened to me, after putting a fresh battery pack and turning the camera to the " on " position, I just tapped on the lenses to push it back in place. Either in or outwards. Hope it helps, good luck
Feb 19, 2010 | Nikon COOLPIX L10 Digital Camera
My auto focus lenses have stopped foucusing. battery is fresh and auto focus is on. Is auto focus the lens or the cameraor both?
Go to your main menu and shop around, you'll find an option to "Reset to factory defaults" click that and you'll be all set.
Sep 06, 2009 | Canon EOS 40D Digital Camera
Dimage Z3 lens does not retract
Check your batteries. Are they working? Try taking them out and replacing them. If you left the camera on when you put it away and the batteries drained, you won't be able to retract the lense until fresh batteries are inserted and the camera is powered up again.
Feb 02, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Lense will not retract even after camera has been charged
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Oct 16, 2008 | Kodak EasyShare V530 Digital Camera
I have a panasonic DMC - FZ8 DIGI CAMERA,when i turn it on it comes up on the lcd screen "remove lens cover and press >,but nothing happens it keeps comming up
Hello
start with removeing the batterys for a minute and if you know how to reset the camera reset it.
It might be a fault in the lens.
let me know if that doesnt solve the problem.
May 14, 2008 | Panasonic Computers & Internet
Fuji FinePix E550 Digital Camera stopped working after fresh batteries inserted
due to very low temprature some malfunction may have occured. keep it in normal temprature for few hours and then try switching it ON. even if this not solves take it to some service centre.
Dec 07, 2007 | Fuji FinePix E550 Digital Camera
Sony camera turning itself off...
You can't use regular alkaline batteries in this camera. Alkaline batteries only supply 1.5 volts. The camera uses 2 in series for a total of 3.0 volts from alkaline. However, the camera requires 4.2 volts to operate correctly. This camera has high power requirements, so you'll need high end lithium or nickel hydride batteries that can supply the higher voltage and current this camera requires. It's a power hog, and regular alkaline batteries are too weak to run it. The menus will work on alkaline, but once you try to turn the camera on in capture mode to take a shot, the current requirements to operate the camera motor, LCD, zoom, memory stick, etc, all it once is too great a draw for alkaline to handle. Either use the external power supply, or get Lithium batteries. Make sure the batteries you get are 2.4 volts and not 1.5 volts. Get the ones with the highest current rating you can find.
Aug 31, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Konica Minolta DiMAGE S414 Digital Camera Logo
311 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
comment
comment
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
