Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
We have a Bosch Fridge Freezer Model No KGV3120GB/03 we wish to reverser hang the doors but can't undo the top post in the fridge and bottom one in the freezer don't want to apply too much pressure in case it breaks is it a screw fitting or a simple push one . can you help?
We have just reversed the doors on our Bosch Fridge Freezer. The posts were very difficult to unscrew but was eventually possible using 2 mole grips. It is definitely a screw fitting. Good Luck.
Posted on Jan 06, 2009
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
Sep 19, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Fan not working
I have a bosch fridge freezer, I bought it only 13 months ago and the fan has stopped working. How do I go about fixing this problem?
Nov 03, 2008 | Bosch KGU32124 Bottom Freezer Refrigerator
Freezer Door
Try undoing the middle and bottom hindges and refitting them straighter you may have to pack the bottom one with a couple of washers.
Nov 28, 2007 | Zanussi ZSS7 / 5W Compact Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
574 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
