Question about Technics SL-1200MK2 Turntable
On/off switch won't stay turned on
My technics are quite old and i went to turn one on the other day and the on/off knob just turns off straight away. It would stay on if i held it in place but otherwise it just flicks off by itself... very frustrating. any ideas??
  • 515 Answers
Knob shaft is probably dirty, or has dislodge inside. Unfortunately, you will have to open up your unit to see what is going on inside.
You can view a video on opening these turntables, by going to: TECHNICS REPAIR VIDEOS.
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Posted on Jan 17, 2009
2008 Nissan Quest Reverse Park aid stoped working. First sound got funny and then quit. The switch disable light stays on and won't turn back on
replace the beeper that makes the sound when you are in reverse.the light will also go out after you replace thet beeper.
Sep 16, 2012 | 2008 Nissan Quest
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
01 ford explorer sport won't stay running. turns over fine and starts but quits right away
Check for vacuum leak at intake manifold or bad fuel pump relay or have fuel pressure checked to see if fuel pump is working properly 40-45 psi it should be pumping
Dec 18, 2011 | 2001 Ford Explorer Sport
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work ) the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many turn all the knobs of new flyback in anticlockwise direction very very very slowly until it fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Aug 31, 2011 | JVC Televison & Video
Press on/off switch tumble drier starts then turns off straight away. is it ok to switch the heat setting knob with the on off knob?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
Aug 19, 2010 | Candy CDV262 Dryer
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Water won't cut off when filling... Hoover Galaxy A6834
Hi Steveb6723 ,Just read your posting.Now here is a little test I need you to preform so I can tell if the problem is your water valves or your pressure switch system.Now 1st turn it to a normal cycle and only select the cold fill.Pull the knob out so it starts to fill.Now turn the machine off at the power point,Does the water stop filling straight away?If it does select hot fill and pull the knob.When it starts filling on hot water turn the power off again and see if the water
stops straight away.Please reply and tell me if the hot or cold water continued to flow when the power was off.Looking forward to your reply.
Jun 24, 2010 | Washing Machines
This is somethig you should have checked by technician.Till then turn the oven off then pull straight out on the knob removing it. use a plyers to check if it's actually turning off by turning it to the left. If it does turn to the left( off position) you may just need a new knob.
Oct 04, 2009 | Ovens
Buzzing noise
This might not work for you, but Syntax LCD tvs have a similar problem straight out of the box. To fix it, I had to turn the backlight brightness to full brightness, at which point, the buzzing went away. You might give that a try!
Feb 17, 2007 | LG 32LX1D 32 in. LCD Television
Technics SL-1200MK2 Turntable Logo
110 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
