LAPTOP BUILT IN MOUSE PAD
I ACCIDENTLY DISABLED MY BUILT IN MOUSE PAD.
HOW CAN I ENABLE IT
  • Anonymous Mar 26, 2014
    I want to disable it
    Problem Solver:
  • 8 Answers
Depending on what laptop you got i got an acer spire 5751z and it can enable or disable the mousepad by pressing 2 keys on the same time:
<FN><F7>
let me know what laptop you got or how it worked out
greetings
Posted on Jan 02, 2009
I switch of my built-in mouse pad. how do I turn it back on?
Acer 8.9 Aspire one.
Posted on Feb 04, 2010
FN F7
Posted on Feb 16, 2010
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
My hp laptop touch mouse pad has stop working
Ensure that you have not accidently disabled it check your function keys for a picture of a mouse with a line through it then hold the function key and that button at the same time.
Sep 04, 2011 | Computers & Internet
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
Mouse pad stalls and i see a little red light on the mouse pad....i have a compaq laptop but not sure what version...how do i disable thi feature so i dont have to use a physical mouse
The little red light is likely from the red LED underneath your optical mouse. If the mouse cursor/pointer on the screen is jerky, it may mean the mouse pad is dirty and/or if the mouse is wireless, its battery is low and should be replaced. Most laptops have a touchpad as part of the keyboard. If you want to use that instead of a physical mouse, just put the physical mouse away and use the touchpad. Both should be active unless the touchpad was disabled. If the touchpad is disabled, you can re-enable it by clicking on control panel > mouse > device settings tab > enable button.
Mar 16, 2011 | Computers & Internet
Mouse wont move
Are you referring to the mouse pointer when using the touch pad? To isolate the problem, try to use a USB mouse and see if the pointer will move. If the USB mouse works, then the touch pad could be disabled.
Refer to the user manual of the laptop and see on how you can enable the touch pad.
If same problem occur even though you're using a USB mouse, contact the manufacturer of the computer for second opinion or repair.
Good luck and have a great day!
Feb 08, 2010 | Dell Inspiron 6400 Notebook
How do i enable my laptop touch pad
Click the buttor or if you use windows go Start -> Control panel -> Mouse -> Synaptics and enable your touch pad.
Aug 08, 2009 | Dell Inspiron 6400 Notebook
I accidently disabled the scroll/wheel feature on touchpad/mouse for note book
go to control panel and look for the mouse icon. from there you can change the settings of your mouse to enable it.
May 28, 2009 | HP Compaq 6735s Notebook
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
634 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
