Question about Dryers
DRYER SHUTS OFF IN THE MIDDLE OF A CYCLE.
MY DRYER WAS TAKING MORE THAN ONE CYCLE TO DRY CLOTHES. WE CHECKED AND CLEAN THE VENT. NOW IT IS SHUTTING OFF IN THE MIDDLE OF A CYCLE. THE CLOTHES ARE GETTING HOT.
  • 91 Answers
NOW REPLACE YOUR COILS,
Posted on Jan 03, 2009
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
We have a LG DLE2516W dryer. It does not get hot enough to dry clothes in less than two hours. We have checked the lint drap and the vent pipe. Both are clean. It does not matter whether there is a...
It could be a thermostat in the unit there are two and it could be registering wrong and shutting down the fire early. No way to check them though unless you put a tester on them while its running and see if they are shutting off the fire during a cycle
Dec 29, 2010 | LG DLE2516 Electric Dryer
My maytag duet electric dryer is heating, all controls seem fine, we cleaned out the lint traps, checked the hose and blew out vent as well. The dryer keeps shutting off early before clothes are dry. They...
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes.
As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time.
If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Dec 10, 2010 | Dryers
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 05, 2009 | Dryers
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Low dry temperature
check your air flow it could be a clogged or pinched vent pipe
Dec 20, 2008 | Maytag Neptune MDG9700A Gas Dryer
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Laundry taking too long to dry!
1. Make sure the filter is clean. A clean filter allows for proper air circulation in the dryer.
2. Make sure the rear dryer vent is clean. Move the dryer, unplug it and remove the rear vent hose and clean out any debris from the vent, in the hose and any debris in the outside vent.
Over time, these things get clogged and reduces the air circulation in the dryer, causing it to take longer for the clothes to dry.
Please let me know if I can be of further assistance to you.
- Jim
Feb 14, 2008 | Dryers
Dryers Logo
193 people viewed this question
Top Dryers Experts
