Question about KitchenAid KSRA25CNSS Side by Side Refrigerator
Hi, Re: Fridge Problem Model: KitchenAid KSRS22 SKSSOO (Side by side with ice) My fridge is broken down, the lights are on, but both sides of the fridge are not working. I heard the beep sound (tempreture alarm) once in a while. Please adivse. Thanks.
  • rebecca739 Feb 26, 2009
    I have the same problem - how did you fix? Thanks!
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
  • 61 Answers
SOURCE: Warm Fridge No Airflow...Control Panel Beeping
i just had the same call today i ordered the damper control because it seems at times more air comes in and than at time like 30 seconds later nothing and the fan is working its not mine fridge but what you can do take the freezer side upper shells off the ice maker on(not necessery but i thought it was easier) and take off the little cover which is covering the damper it has two screws and look inside of the opening and you'll see a damper, turn up the fridge and see if the damper moves and you can turn down the fridge and see if the damper is moving if not you need a damper! good luck
Posted on Jun 06, 2009
aasc
  • 1606 Answers
SOURCE: KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Posted on Aug 02, 2009
SOURCE: Kitchenaid fridge #KSCS25INSS hot door frame
how to change the waterhose my Kitchenaid fridge #KSCS25INSS
Posted on Sep 12, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
May 20, 2009 | KitchenAid KSSC42FMS Side by Side...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Sep 17, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker Not working
No it should take about 24 hrs to get a full bin of ice. The most common problems with this style icemaker is the fill tube freezes which they have a replacement heated fill tube or the board on your freezer wall that pass a light through your ice bin to tell if its full or not stops working
Dec 05, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRA25CNSS Side by Side Refrigerator Logo
49 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
