Gudevening! my problem display in my monitor
What's the problem i try to clean not work
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Is there an error message displayed?
    Problem Solver:
  • 11 Answers
Hello, Hola, Hej
If you want you can repost the problem in more detail in your natural language and I can translate it and maybe give you some feedback.
Posted on Jan 10, 2009
    New Friend:
  • 59 Answers
Hellooooooooooo
wat's ur problem??
stripped display?? or no display??....................?
Packardbell imedia
Hi paul,
1. check signal cable from pc into monitor and try to use other signal cable also do try into other monitor if prob cant solve.
2. your imedia include with graphic card? If has a graphic card try use other good graphic card to test the display run or not. If cannot.
3. Try make some cleaning into your ram, Test your ram one by one because sometime no display appear because of broken ram.
Try check this 2 site to other solutions..
Thanks..
1. How To Test Computer Monitor That Won Display Or Is Not Working
2. Fix Your Computer Monitor When the light is yellow or amber not green (try this one)
Good Luck.
Jan 19, 2014 | AMD Computers & Internet
No screen display msi megabook s260
If you have a desktop monitor available try hooking your laptop up to that. if you get a display on your desktop monitor then that means your laptop screen needs replacing. If you get no display on your desktop monitor then that means the GPU chip in your laptop has gone bad.
Sep 12, 2012 | MSI MegaBook Computers & Internet
No display on monitor
Open your computer and discharge static by holding the chasis casing of your system unit for 1 minute. Then start cleaning your video and memory card and also the their slot by using vacuum cleaner and small paint brush. Then put it back again and test for a display. Most of the time because of the dust covered the slot or the pin of the video and memory so the system did not detected that hardware that is why those hardware will not functioning. Clean and test have a nice day!
Jun 04, 2011 | Computers & Internet
No monitor display
there is something wrong with your ram....take it out n clean it with rubber....den agin hook it up in its place...after dat it ll work....otherwise u need to replace ur ram
Sep 01, 2009 | Intel D101GGC Motherboard
Cpu lead lights on but no display in monitor
check the RAM condition, For that remove the RAM from mother board and clean the two side of RAM contact terminals wiping with the eraser and insert it again into the mother board.
if you have using more than one ram just remove both the RAMs reinsert one by one after cleaning the RAMs one by one .
Jul 07, 2009 | EliteGroup ECS 755-A2 Motherboard
Horizontal lines that look like streaks or smears going from left to right
Horizontal lines that look like streaks or smears, you need consider:
1) video card memory error cause it if the display memory on the video card
2) check RAM (clean pins and slot pin)
3) monitor power on without cable to see the menu display, it is ok if no streak, need to clean monitor cable plug.
Aug 25, 2008 | Dell E207WFP LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Hi mr. noggin
http://docs.info.apple.com/article.html?artnum=61671
Jan 11, 2008 | Apple iPod nano
Blinking green light with no display
Have you tried connecting this monitor to another computer?
Have you tried resetting the BIOS? That should reset any problem the video driver for the monitor maybe facing.
Oct 17, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
