Question about Sony Cyber-shot DSC-W170 Digital Camera
How to switch off the flash
How to switch off flash of camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
In the shooting mode press cursor-right repeatedly to cycle through the various flash modes. To turn off the flash choose the lightning bolt in a circle with a slash through it. Full details are in the "Flash (Selecting a flash mode for still images)" section of the Cyber-shot handbook (page 26 in my copy). If you need the handbook and/or the manual you may download them from here.
Posted on Oct 22, 2012
SOURCE:
Flash issue
There\'s a little switch between the pop up Flash and the top of the camera that sounds like its stuck down, its under the flash when it\'s up, look for this switch and see it if it goes up and down, if not then it needs repair.
Oct 26, 2013 | Canon PowerShot S5 IS Digital Camera
Flash is not firing
Very little to go on, but in every camera you can switch off the possibility to flash. How to switch it on must be very easy, because it is always in the top menus of every camera. Looking on the back of your camera, with the menu on, you should see a flash symbol, with a bar through the symbol, then it is off. Try to switch it on. If the symbol is on (without bar) look if it is dark enough so the flash should work. You also could try to reset the camera to the default settings. But is the flash still does not work something else could be wrong. Just try an external flash. If it does nothing, after you tried everything above, I can't think of anything else. Success.
Oct 24, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
I am getting this message on my EOS 450d, (camera's built in flash pop up was obstructed turn the power switch to off and on again). I have done this several times the flash wont pop up - can you please...
Sometimes the pop-up flash on the EOS range of cameras can get stuck. The EOS family have a very tiny micro switch under one blade of the flash hot-shoe.
Get a toothpick and manually pop the switch. It should clear your error, too.
Good Luck.
Mar 28, 2011 | Canon EOS 450D Digital Camera
Yesterday I was taking pictures with my Canon 5d MarkII and Speedlite 580X. I control the flash from the camera enu but at some point the meanu was no longer accesible and I got a message that either the...
It sounds like the flash went to sleep. The normal time for this is 10 minutes. If you switch the camera over to slave mode, it should switch to 60 minutes.
I hope this helps! That's a great setup!
Mar 06, 2011 | Cameras
The flash is in macro mode. What does that mean and how do I get the flash to turn on?
The macro mode is for taking pictures of subjects very close to the camera. The camera disables the flash in this mode. There's a switch on the left side of the camera, near the USB port. Slide this switch away from the flower symbol and toward the mountain symbol to switch out of the macro mode.
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
My camera wont flash ... How do i get it to flash ?
Most cameras have a button that looks like a lightning bolt. Hit that button and it will usually switch between flash options or it will bring up a flash menu. Some camera modes will automatically set your camera to auto flash, so if the room is dark, flash is on, and room is light enough the flash shuts off. You might need to switch to a different picture mode, like P or Programmable that lets you manually set your camera options.
Nov 08, 2010 | Cameras
How do i make the camera flash
Make sure you're not in the macro mode. There's a switch on the end of the camera, near the SD card slot. Set this switch to the mountain position.
Also bear in mind that the flash is for still pictures only, not for videos.
Feb 23, 2010 | Vivitar ViviCam 5022 Digital Camera
Flash not working
First, be aware that the flash only works in still mode, not in video mode.
Second, check the macro/far switch on the left end of the camera. The flash won't fire if this switch is in the macro position (flower icon).
Feb 13, 2010 | Vivitar ViviCam 8025 Digital Camera
My olynpus camera says write protect how can i solve it?
If your camera uses flash cards for storage you can check your lock switch on flash memory card.
On some digital cameras you can find switch inside that detect flash card switch position.
Try this solution for Panasonic DMC-LZ5 digital camera.
More detailed information you can find here
Dec 21, 2009 | Cameras
Flash stopped working after 1 month
I had the exact same problem,on the back of the camera there is a 3 position slide switch make sure its in the position that works with flash mine is in the middle spot I think the switch is/was a bit dicky try playing with the switch a bit,anyway mine now works 100%.Try it anyway.John Leigh.
Apr 15, 2008 | Nikon COOLPIX L10 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
