Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother MFC5440CN - Yellow cartridge does not print despite being
Yellow cartridge does not print despite being full.
Have taken cover off to view ink hoses. Have removed cartridge and tried to syringe air down the hose only to find the ink retracts again once the air pressure stops so I can only assume there is a firm blockage either along the hose or at the print head end. I can't work out how to get inside the print head though so am a bit stuck.
What should my next step be?
I'M HAVING SAME PROBLEM WITH THE YELLOW ALSO, DESPITE HAVING A NEW CARTIGATE
PLEASE GIVE SOLUTION
Posted on Jan 18, 2009
    Problem Solver:
  • 8 Answers
Print head will have to be replaced. Whenever one or more colors won't print and you've gone through the cleaning process, the printhead is bad!
Posted on Jan 02, 2009
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
Doesn't print black ink
Have you taken the protective film/sticker off the cartridge? - so the ink can get out...
May 06, 2010 | Brother MFC-685cw InkJet Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Mar 01, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
When printing the test page
there is a problem with your cartridge and the head of your printer, because if the software is telling you that the cartridge is full therefore it could be an hardware issue, i suggest that you should try to removing and reinstalling the cartridge, if that step still dont work then bring it to a service technician and ask them to clean the head of your printer!
Hope this one works!
But i know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Jul 26, 2008 | Brother Office Equipment & Supplies
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
293 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
