Question about Olympus D-460 Zoom Digital Camera
Need serial adaptor/cable
My Dad updated his computer and it has no serial input...his camera cable has the 9 pin serial connector.  Do you have a way to adapt this....maybe to USB?  Or is there another solution...he likes the camera and is 82, so I would like to not change cameras. Thanks John Shimp
    Sergeant:
  • 306 Answers
Welcome to FixYa! There are DB9 to usb adaptors at any electronics store like Radio Shack or Fry's. Also there are serial connectors that connect internally to motherboards having a COM port connection if this is a desktop/tower computer. Though he likes the camera he might like the fact that newer cameras have a much higher resolution than previously available for much less than he may have paid for the present one.
If you have any further questions feel free to post them here and include the brand/model of the new computer. Steve Medley
Posted on Jan 09, 2009
  • Stephen Medley
    Stephen Medley Jan 09, 2009
    One other factor, John. Note the gender of the DB9 or take the camera with you as there are male and female versions. Steve
Were can i buy 9 pin cab;e
Shop for 9 pin cable on Google
9 pin serial cable ' Staples®
www.staples.com/theme_9-pin-serial-cable
Staples Inc.Items 1 - 18 of 8325 - 9 pin serial cable (8325 items found) .... Professional Cable (9); Voxx (9) ..... QVS 4.5' USB/DB9 Male to Female Serial Adapter Cable, Black.
Sep 25, 2015 | Video Cameras
To connect gps to computer wich pins do i connect of nmea cable?
pins 2(-) and 5(+) on a 9 pin serial cable, then you need a usb to serial adapter for input into the computer if you do not have a built in 9 pin serial port on you computer because the usb moves the information faster than the gps signal. gps is roughly 4800 baud, usb is moving so much faster you need a buffer
May 19, 2010 | Furuno GP32 GPS Receiver
I have the garmin extrex legend and need to install the update for the freezing problem. I have the Garmin cable (9 pin to the 4 slide contacts) but, I'am using a dell mini with no 9 pin male...
you can buy a USB to serial adaptor at almost any computer store. it will install and show up as a com port, you can then update that way. i have the same GPS.
Nov 25, 2009 | Garmin eTrex Legend GPS Receiver
Downloading from digital camera
Serial data bus interface 9 pin to a 25 pin are they still available. may be a computer salvage place the adaptor is shaped like a flat flask I rember them from the late 80. serial bus cards use to have them as standard features.
I have the adaptor and saved it for someday I may need it. have not yet .
Jul 29, 2009 | Cameras
Only have one serial port on my cpu can the monitor plug be switched
there could be another port for the monitor to use a VGA cable. check and see if your computer is capable of VGA from the port of the back of the computer and if it is. use a VGA cable to connect the computer to the monitor.
Jun 08, 2009 | HP Computers & Internet
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Fitting an internal card reader
hello weave!m just curios if that 9 pin is a serial type connection?then if it is..you shoud find an adaptor for a serial port or any port that fits ur 9 pin connector.if u can find a PCI card that has a 9 pin port..then you can connect..just feed me back for your more details.
Jun 19, 2008 | Dell Dimension PIII Tower Computer XPST500...
CONNECTION CORDS CANT PLUGIN TO NEW COMPUTER
Part # Description Price Qty 28UC-18000 USB / DB9 Converter / Adaptor with 6 ft USB Cable 23.10
Apr 19, 2008 | Vivitar ViviCam 2700 Digital Camera
EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
My computer only has a 25 pin serial port. How can I connect the camera?
If you only have a 25 pin serial port available, you can use a 9 pin - 25 pin adapter to connect the serial cable from the camera to the computer. Another option is to add an addition serial interface card to one of your card slots. These should be available at local computer stores.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Olympus D-460 Zoom Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
