Question about LG WM-1832C Front Load Washer
LG washer with UE error issue
Hello Richie,
Thanks for the quick response with your solution to my washer (LG WM1832CW) 'UE' error issue. I understand it is a sensor issue and a quick fix would be to \'foam\' the drum to reduce the bounce of the drum.
I am not a expert mechanic. Can you describe in detail how i can add foam to the side of the drum? Is this something a novice like myself can fix or does it require hiring professional help?
Sincerely,
Tang
    Genius:
  • 1,036 Answers
This is fairly easy to do, although you need to find some suitable foam - two pieces about 8" square and probably 3" - 4" thick.
You will also need a suitable adhesive, which could be spray carpet adhesive, copydex, or silicone sealant.
Turn off and unplug the machine, "walking" it out slowly if it's under a counter. Do not strain the water hoses too much.
Undo the few screws along the top at the back that holds the lid on, then slide the lid back an inch and lift off.
There should be some foam buffers in there already - but may have fallen off. Retrieve them if they have, but fit your bigger ones instead to leave maybe a finger width gap each side of the drum.
Make sure any springs on the top you can see are ok while you're there.
Once fitted, refit the lid and screw back, then push back the machine from very low down - check hoses are not squashed, and the outlet hose is ok.
Turn on again.
Posted on Jan 02, 2009
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
My WM1832CW front load machine consistently gives me the UE error code during the spin cycle regardless of the contents or size of the load. Its a direct drive system - so what could be the problem?
bad imbalance sensor. silly little contraption that sticks off the back of the drum. It is a plastic lever with a light sensor attached to the end. there is a hole and a bb that sits in the hole. when the load gets imbalanced, the bb gets knocked out of the hole and the light shines through the hole. the light sensor relays the error to the computer and it displays UE. I took the sensor apart, and put a piece of tape over the hole so the light cant shine through anymore. No more UE code. LG parts are very hard to find. I dont mess with them, but it was my neighbors machine. This will get them by until they can buy a new washer. good luck.
Jul 20, 2011 | LG WM-1832C Front Load Washer
I have a DE code on my LG Wm1832cw front load washer. This happened last weekend, and we found that the small drain hose in the front was clogged so we got the clog out and the washer has worked great all...
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service manual
May 27, 2011 | LG WM-2277HW Front Load Washer
The washer shows a UE error during the final spin. It does not reach the fast spin speeds, but shows the error after 5 minutes.
hello ue is an unbalanced error one of the first things you can do according to lg is click this link to try to aleviate the issue http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800 also check with a level that your unit is leveled if it is not then you would get this error code as well if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 21, 2011 | LG WM-2277HW Front Load Washer
What is the error ue ?
You did not mention what make or model of your washer. If it is a LG, UE means an unbalance load. This means that your load is too small, or the wash is gathering on one side or it is unable to distribute the wash evenly. Try adjusting your load size.
Aug 23, 2010 | Washing Machines
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
Error code UE will not spin fast except on quick wash, or if i push SPIN SPEED and SOIL LEVEL at the same time
UE could mean user error, or if the washer senses an unbalanced drum 3 times in a row which might cause it to not spin at high speed. It could also be a control board problem. Sorry i couldnt help more
Mar 13, 2009 | LG WM-2032H Front Load Washer
LG washer (WM1832CW) error: UE
This is a problem with modern machines that have a lot of sensors - compared to older models that just used to bang about a lot.
The dampers on this machine may not have been 100% since day 1, so should be replaced. It is their job to reduce the bounce in the drum. As a "belt and braces" attempt, manufacturers often fit foam blocks to the sides of the drum, and there is no reason why you shouldn't fit larger ones to fill up the gap entirely. Foam is cheap, so just use silicone to attatch it either side of the drum - leaving just a centimeters clearance on each side.
This should solve the problem.
Dec 31, 2008 | LG WM1812C Front Load Washer
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Jun 20, 2008 | LG WM-2077C Front Load Washer
OE message on our LG WM1832CW washer
I just was searching for the same exact error on my LG WM1832CW washer. From reading the other posts on different manufacturers I realized this was a pump clog issue for mine too. There is a small door near the bottom of the front of the washer and if you open that there is a filter basket. Once you start turning it and break the seal, the water will come out quickly, have 2 flat large tupperwares so you can catch the water. Once you clean out that filter it's good to go. A 5 minute job.
Jan 21, 2008 | LG WM0642H Front Load
LG WM-1832C Front Load Washer Logo
126 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
