Question about Hotpoint Ultima WF860 Front Load Washer
Wt960 drum judders and wont turn smoothly
Even when empty the drum judders and goes around in fits and starts. Just started this morning ?
    Problem Solver:
  • 8 Answers
Not enough info but could be one of two things "brushes or bearings" the fits and starts says brushes need changing in the motor. If its bearings put your hand on the top of the drum and lift slightly upwards if there's play in it then it's the bearings
Posted on Jan 08, 2009
Drum wont turn when i start it even though there is power going through
have u checked the belt that goes around the drum and motor pulley?
Jun 16, 2014 | Dryers
Wont start
Sounds like a wiring problem at the gas tank.
I would check for voltage and ground for the fuel pump and the sending unit for the gauge.
Aug 17, 2012 | 1995 Ford Contour
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My 04 1.6 renault megane struggles to start in th morning and once it does fire up you hav to rev it to ensure it wont cut out. The car then splutters and judders a bit till its warm then it tend to run...
My 05 1.6 renault megane struggles to start in th morning and once it does fire up you hav to rev it to ensure it wont cut out. The car then splutters and judders a bit till its warm then it tend to run ok. but keeps on switching off at the robots when i stop please what could it be
Sep 30, 2010 | 2003 Renault 181
The drum wont go around and it smells like its burning.
if you can turn the drum by hand it may be the motor start capacitor.fitted just above the motor if you cant turn the drum one of the drum seals will have jammed the drum the belt will have snapped as well.
Aug 06, 2010 | Zanussi TD4112W Electric Dryer
2004 ford taurus occasionaly wont start right up.
Can you tell me if it was in fact the starter? I have an 04 Ford Taurus with 99K miles on it. This week when I started it up, not everytime but often the abs, brake, tire and traction control lights will stay on. Also the computer display will read either park brake engaged or passenger door ajar. I turn it off and start it again and the issue goes away. This morning it acted as though it had a dead battery and I had the clicking sound behind the dash as well as the vibrating needles. Thanks!
May 06, 2010 | 2004 Ford Taurus
Ford mondeo 1.8 lx 53 reg. This car is used as a taxi so has done alot of miles. Previoulsy had trouble before when the car was juddering and losing power so i put engine cleaner in the fuel tank to clean...
Probably it is the fuel pump,make a test take out the fuel hose which goes to the fuel rail,then turn the engine to see if fuel comes out sufficiently,then you can know what step to move.
Jan 12, 2010 | 1995 Ford Aspire
VW touareg steering judder low speed left/right turn
Sounds like you have air in your steering system. I would start by looking for any leaks on your steering system like hose to fitting crimps, steering pump, etc. Check your steering fluid level to make sure it is full and also look for bubbles on the dip stick. If everything looks good, start the vehicle and turn the wheels all of the way to the left and then to the right. Do this while the vehicle is in park and repeat at least 5 times. This will work out any air in your steering system. If the problem persists then the power steering pump may need to be replaced.
May 24, 2009 | 2004 Volkswagen Touareg
Juddering when i pull away from a standing start.
it sounds like the thrust bearing is on it way out, have you just had a clutch fitted?
Jan 22, 2009 | 2004 Audi A4
Hotpoint Ultima WF860 Front Load Washer Logo
226 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
