Question about Acer AL1716 F Monitor
About the system's requirements
Hello i am having a problem regarding my systems monitor some times in the middle of some programming disturbances are being occured likes lines in between can u help me to take some necessary steps to prevent this specified problem
  • 56 Answers
That me be because of the graphicscard geting hot, if you could get a new graphics card or better cooling on the one you have, the lines should dissapear
Posted on Jan 02, 2009
602 error code
E602 is a hard disk error. If the machine is coming up and working sometimes and not others, then either your hard drive is going bad or there is a corrupt file in the firmware. Try reloading system software if the issue is still present replace the hard drive. Loading system software requires special software (Service Support Tool) made by Canon.
Mar 11, 2012 | Canon imageRUNNER C3200 Copier
I can only see top corner of screen
This sounds like you have the wrong video ratio configured in the game. If possible, see if you can access the in game menu and change the video settings to the appropriate ratio ( 1620 x 1200 etc). If you can't access the menu, you may want to uninstall and reinstall the game.
Additionally, some games have a separate launcher program you can run(within the install folder, usually located in C:\program files) which you can change video settings.
Further, make sure that your system meets the required system specs to play the game properly.
You can check the system requirements at the link below. It is the manual for the game. The last couple of pages should show this information.
Click Here
Regards,
G33k
May 07, 2011 | 2K Games Joint Task Force for Windows
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Mar 14, 2011 | NorStar T7316E Corded Phone
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
From the manual: You need to program a button with FEATURE 01.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
Mar 16, 2010 | Lands Phones
Hey dudes i have a problem with farmville. my window is disturbed and moved a bit to the right side so i cant see/use the fullscreen button. can anybody help me?
Hi
Hey dudes that is a symptoms of a virus infected. You just do some tweaks in order to works it normal again. Click start> programs > accessories > system tools > system restore, then set it to the date where PC is in good condition. Hopes it may helps.
Regards,
kaybicks
Feb 26, 2010 | Microsoft Windows Vista Home Premium with...
Why wont wizard uninstall print shop 15
Dear the uninstall wizard is basically a program to remove the files of a specific software from the system, the uninstalled wizard is disturbed, thats why is unable to uninstall print shop 15. You need to reinstall it in order to make corrections to the uninstall wizard. or need to install the operating system again.
Best regards.
May 18, 2009 | Computers & Internet
Source code for asset tracking system
just take a look to this site:
http://www.codeproject.com/
you'll get all your answers about VB and totally .NET there by a simple search
enjoy it!
Feb 21, 2009 | Microsoft Visual Basic 6.0 for PC
Monitor
It would seem that you do not have a computer problem but rather a monitor problem. If you monitor displays a single line from left to right, then chances are that the vertical IC is defective and would require replacement. In some instances, the IC may not be defective but would require reheating the solder joints. In some other instances it may be the vertical capacitor and/or some other associated components.
Since this would require opening the monitor, familiarity with electronic components & circuitry, use of a DVM and/or a soldering iron, then perhaps your best bet would be to seek the services of a qualified monitor technician.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
good luck and kind regards.
Dec 12, 2007 | Dell Microsoft Windows XP Home Edition
Acer AL1716 F Monitor Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
