Question about Gigabyte 8S651MP-RZ (GA-8S651MP-RZ) Motherboard
Two sets of power leads to motherboard from pwr pk, 1 x 20 pin and a 4 pin, when the 4 pin isn't attached to the 8s651mp-rz motherboard the fans spin, the mother board light comes on, but then does nothing, no beeps, no power to monitor. when the 4 pin is attached to the motherboard, nothing happens on pressing the power bitton! nothing at all. n e thoughts?
    Scholar:
  • 99 Answers
The 4 pin connector is required as it provides the power for the CPU to run. if nothing is happening with the 4 pin connector plugged in then there is a problem. You need to make sure that you Power Supply can supply enough power for what you are connecting to it (400W would be the bare minimum with no high end video card, 500W would be recommended). You also need to make sure that the Power Supply is connected properly because some Power Supplies from pre-built systems from companies like Dell are wired differently than the standard power supplies. The only other likely problem is that there is a short on the motherboard either from the mounting of the motherboard in the case or from something on the motherboard being bad. Make sure there is no metal touching the motherboard except at the holes used for mounting.
Posted on Jan 03, 2009
Motherboard diagram
Hello i can help you with the manual:
http://www.gigabyte.com/products/product-page.aspx?pid=1792#manual
There are no fuses on the mainboard, not even in the powersupply.
The power supply maybe contains a thermal switch, but it does not pay to let it be changed.
The solution is to buy a new or used power supply.
If still no life when the power supply is changed, the mainboard is dead.
Good luck
Jun 25, 2013 | Gigabyte Giga-Byte: 8S651MP-RZ...
I need audio driver for gigabyte 8S651MP-RZ for xp 32 bits
The Gigabyte GA-8S651MP-RZ motherboard uses a Realtek ALC655 audio chipset,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128258R
Scroll down;
OnBoard Audio / Audio Chipset / Realtek ALC655
Realtek Support,
http://www.realtek.com/downloads/
Click on High Definition Audio Codecs (Software)
Click in the empty square box to the left of -
I accept to the above
Now click on Next
Under the Description heading go down to the green -
Windows 2000 / Windows XP/2003 (32/64bits) Driver only
(Executable file)
Go to the right, and click on the country abbreviation that is closest to your country.
[United States 2, United Kingdom 1, Canada, United States 1, Hong Kong 1, United States 3 ]
A small window will come up on the right -
Opening WDM_R270.exe
Click on Save File.
A small window will come up on the left.
Allow the file to fully download, then DOUBLE-click right on the file name.
Follow the easy instructions.
[If a Microsoft 'Squawk Box' opens up, ignore it. Click on OK ]
Regards,
joecoolvette
Oct 04, 2012 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Gigabyte 8s661fxm-rz motherboards (x3) No video output on start up.no bleeps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
if this fails to fix the problem
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
May 07, 2011 | Gigabyte GA-8S661FXM-RZ Motherboard
Where to connect my sw pwr chords since i removed all the chords to clean my pccccccccccccccccccccccccc with diagram ga 81865gm-775
If you MB model is 8S651MP-RZ, you can download manual on this page:
http://www.gigabyte.com/products/product-page.aspx?pid=1792&dl=1#manual.
Also, try reading the inscriptions around the connectors.
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 02, 2011 | Gigabyte Giga-Byte: 8S651MP-RZ...
When i switch on the cpu ,fans are running ,what no display on monitor,pls give solution for this problem
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Hi. i have no signal to monitor, keyboard flashes lights then nothing, mouse stays lit, can hear drive attempt to start..! Motherboard ?
make sure this hard drive is getting power
Test or replace your PSU power supply unit
one bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps?
Nov 22, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Vga sis 651 for 8s651mp_rz
You can download the video drivers from Gigabyte WEB support site. Please click on this link and select your model motherboard and drivers you require :-
http://www.gigabyte.com.tw/support-downloads/support-downloads.aspx
Aug 14, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
How do I plug the Power Button wire into the motherboard?
Printed on the MB
HD LED +1 -3
PWR LED +2 -4
RESET 5- 7+ (Why the changed order? & there's no reset button on this computer.)
PWR ON +6 -8
There are nine pins with a little triangle pointing at one and a 2 next to another.
The pins on the MB look like this:
2ndpin
1st pin
Found some info on the 506GR. Unfortunately Gateway is keeping the service manual a big secret.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | Computers & Internet
GA-8S650GXM FOR USB FRONT AUDIO PANEL
You will need the motherboards manual to help you with connecting USB_1, USB_2 and F_PANEL audio to you're case. If you do not have you're manual for the GA-8S650GXM you can download it from Gigabyte; http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s650gxm_series_e.pdf
You will also need Adobe reader installed to view the manual.
Gigabyte GA-8S650GXM main web site; http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1658
Turn to page 18. Number 17, F_USB1/F_USB2. Use the link provided below to help you connect you're front case USB wires to the motherboard; http://www.directron.com/installusb.html
Turn to page 24, for front audio connections. Keep in mind once you configure you're audio to function from you're cases front audio port you will not be able to use the rear audio port. Caution, most people find bumping any front case USB or audio cords break far too easely. To avoid breaking the front audio port, consider using a Y splitter for the rear audio port as shown in the next link; http://shopping.yahoo.com/p:StarTech.com%20MUY1MFF%20Audio%20Video%20Cable:1991733360;_ylt=Ah94ikZN9zDbTi2.arc45BkbFt0A
Hope you find this helpful.
Mike
Jan 22, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Gigabyte 8S651MP-RZ (GA-8S651MP-RZ) Motherboard Logo
98 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
