Philips portable tv 14pt136b/05 how do u tune in a channel
3 Suggested Answers
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Posted on Jul 17, 2008
SOURCE: Tuning a Channel
To Tune in Philips Machline TVs
Without using remote. Open panel on front of tv
1-- Press the menu key. --screen will now display 5 menu options--
2--press the down arrow key untill Install is highlighted
3--press the vol + key -- now install options appear (language--autotune---mantune--channel no--store)
4--press the down key to select the function required (Autotune is best) Manual is ok if the tv station's freq are known and they can be then given a ch no
5--press the + key to start the function selected ---tv will auto tune in tv stations when completed
6--press down arrow and highlite store then press ok
7--Press menu to clear menu off screen
Posted on Oct 29, 2008
I'm trying to tune my Philips 26PFL5522D/05 tv digital channels without a remote. If i press the menu button I do not get 'Install' as an option in the drop down menu. Whats wrong?
I don't believe there are analog channels being broadcast anymore, or I know around here we don't have any, the set should pull up anything that is available without doing anything special to it. Below is a link that will explain it.
Are Analog Cable Channels Still Available Enlighten Me
Feb 11, 2018 | Philips Televison & Video
Need to tune in Philips Tv 14pv284/05 lost manual
If you're trying to scan for channels, this option should be found in your menu. I am not sure what your menu looks like, but usually there is a "Channels" setting in your menu. You can then select "Start Scan" or "Scan for Channels." You might also look for anywhere that says "Initial Setup" or somewhere in the menu that says "Add/Remove Channel." For some reason, Philips does not allow you to look this model up on their website. If you can't figure out the menu you should try calling Philips customer support.
LCD Television (2008 and newer)
1-866-771-4018
Televisions (purchased before 2008)
1-866-310-0787
May 01, 2011 | Televison & Video
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
How do i tune in a channel
Go to menu and select/autoscan, then if autoscan can't tuned then select manual.
Hope it may help you;
Regards;
VOTIT
Jan 02, 2009 | Philips Televison & Video
Tune 14 inch TV on remote ie BBC1 on No 1 thro to No5.
here is a link to thhttp://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=TV_CONVENTIONAL_CA&sct=COMBI_TV_SU&session=20090102155334_65.38.34.98&grp=TV_GR&ctn=14PV182/05&mid=Link_UserManuals&hlt=Link_UserManualse manual
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
My dad has just been given philips 21 pt1532/05 tv with original rcu but no instructions can you remind me how to tune it in. (iused to work for granada tv rentals so am quite competent at tuning tv's etc
Go to menu look for autoprograming press and set auto it will then tune in all channels that it recied signal too.make sure if you have cable /air is switch on.
Jan 26, 2008 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
