I tried to connect to the Internet through Wii , It said that the Wii has been updated , and asked me "do you want to use Wii shop Channel and WiiConnection24 ?", i pressed "Yes" , then a black screen appeared, and nothing happened , i even tried to turn it off but that didn't work , so i unplugged it , and plugged it back again after a minute , and when i turned it on it shows :" Error:003 unauthorized device has been detected " , so please can you tell me if i can fix it or should i buy a new one ??? please give me a solution , i would be soo thankfull than you
Error Message: Error 003 Unauthorized Device Has Been Detected
Situation:
System is displaying error message: Error 003 Unauthorized Device Has Been Detected
Information:
This error code indicates the region the system was manufactured for is not compatible with the Wii System Menu update. This incompatibility has made the system unplayable and it cannot be repaired. Nintendo is not able to provide support for these systems.
It has been modified so you will have to buy a new console sorry.
SOURCE: I have a Korean Wii. I dont know the system
I dont know the system details. I was trying to update the system with a wireless internet connection and I now get the Error 003: unauthorized device has been detected. How do I recover the system?
SOURCE: my wii is showing error 003 "unauthorized device
Sounds a hacked Wii. When you updated the
firmware found the hack and now your Wii may be bricked.
You can try this: While holding down the reset button, turn on the power to the Wii. If a
menu comes up then your wii is definitely hacked but it has a brick
safety program to get you out of it. If nothing happens then you may be
out of luck.
Good luck.
SOURCE: my wii has an error 003 when i open it , it tells
no one can fixed it yet,because the original region your wii is KOREAN but been update to wrong region,..it's totally called BRICKED
There is no need to have
technical knowledge to do fix this problem.....Just get repair guide from
internet and follow the steps in it and fix your problem by your own.......
Click here to download repair guide
you can do
torrent search .....
if you get any
problem it while installing you can refer this guide it will be more help
full
Click Here to do so
come on people , there's no solutions , or what?? please i need a solution to fix this problem =(((( help please :'(
