Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How to clear nvram
How do you clear the nvram on a b350? the meter count is not correct i did a total clear and that did not work please help
  • first last Jan 02, 2009
    found out this is impossible.... must be sent for exchange through kmbs
How to do reset nvram for HP 4250 laser printer,
Posted on Mar 02, 2009
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
How to solve error code C-D301 on bizhub C250
NVRAM Non-volitale Radom Access Memory is bad. Re-flash with updated firmware. Only from Konica Minolta secure website. If not have to have it replaced. NVRAM keeps meter count and certain important copier machine information. associated with that serial number machine.
Apr 17, 2014 | Konica Minolta bizhub C250 All-In-One...
Zero counter
You have some how reset the NVRAM and there is no way to get it back. Its like resetting the odometer on a car. There should be a hard meter located near the main power button.
Apr 04, 2014 | Konica Minolta bizhub Office Equipment &...
Memory full error
nvram needs reset. 1. Power off 2. Power on while memory count is counting up press and hold green check button till all 3 lights on solid.3. Press up button until nvram init appears. 4. Press select button. can google hp 4650 nvram reset for instructions if these dont work
Nov 06, 2013 | HP LaserJet 4650 Color Printer
Hp laserjet p3005 68.1 error coming
The actual error says that the hard drive is bad. I bet that you don't have a hard drive on your printer, so read on...
From the manual
NVRAM initialization
CAUTION Initializing the NVRAM resets the serial number, the event log, the page counts, and
the EIO card (initializing the NVRAM resets SERVICEmenu values to factory defaults). Use the
service menu to restore the serial number and page counts. Also reconfigure any computers that
print to this device so that the computers can recognize the device. Initialize the NVRAM only
when absolutely necessary. In most situations, use a cold reset rather than a NVRAM initialization
to reset device settings (this will retain the values in the SERVICEmenu).
NOTE Before performing a NVRAM initialization, print a menu map and a configuration page
. Use the information on the configuration page to reset
any customer-set device configuration values that the NVRAM initialization procedure changes.
Take special note of the total page count, maintenance count, and the serial number.
1. Remove any installed accessories.
2. Turn the device off.
3. Turn the device on. When the memory count begins, press and hold the button. Continue
holding down the button until all three device control-panel lights flash once and then remain
on. This might take up to 10 seconds.
4. Press the button.
5. Press the Menubutton. The display should show SKIP DISK LOAD.
6. Press the button until NVRAM INITis highlighted.
7. Press . The device initializes NVRAM and then continues the power-on sequ
Jun 20, 2012 | HP LaserJet P3005n Printer
Hi . my copier is aficio 700 .The error is sc 900 .that relate to electical counter .I Check the connection between the NVRAM and controller. Replace the NVRAM. Replace the controller. but the error not...
Other possibilities
A095/A096/A097
SC 900
[SC900] - replace fuse 8 0 4, DC power supply
A109/A172/A199
SC 900
[SC900] - replace black total counter
A133/A195/A217
SC 900
[SC900] - CN4 0 3 SCU PCB, poor connection
A133/A195/A217
SC 900
[SC900] - replace SCU PCB, see FSM page 5 64 for rom and dip switch info
A193/A224/A264
SC 900
Total counter error: Fuse #5 on PSU blown
A193/A224/A264
SC 900
Total counter error: Total counter defective
A229
SC 900
[SC900] - NV ram defective
A230/A231/A232
SC 900
[SC900] - re load copier firmware
A246/A247/A248
SC 900
[SC900] - replace counter harness
A292/A293/B098
SC 900
Electrical counter fail - Replace Mechanical Counter
A292/A293/B098
SC 900
Electronic counter error - Replace NVRAM-B098 9590.
A292/A293/B098
SC 900
[SC900] - replace IOB PCB
A294/A295
SC 900
[SC900] - NVRAM defective
B010/B188
SC 900
Electrical total counter error - NVRAM data defective
Jan 28, 2011 | Ricoh Aficio 450 Copier
I can not clear the error (49.4C18) on the 4350 printer. Is there a way to fix it?
This error can have a number of causes. Sometimes, a corrupt file, or pdl string from certain applications can cause this. It could be something on the formatter. You could try to take out any added EIO cards, hard disks, or font or memory Dimms and power on to see if it clears. If so, then try to add them again one at a time to see if any cause an issue. If it does occur; make sure to clear the offending print job from the print queue before going any further. If any Dimms or cards, etc. are the cause, then replacing them should help. If you can get it to clear, going into the CONFIGURE DEVICE / RESET MENU and resetting to factory defaults may help, or in some more extreme cases an NVRAM initialization, but it resets the page counts and serial numbers and other system settings. An NVRAM INIT is done like a cold reset except when SELECT LANGUAGE appears scroll to NVRAM INIT. It could also be an issue with the original JetDirect embedded print server.
Sep 11, 2009 | HP LaserJet 4350 Printer
A 5115 total count has cleared, is there any way
Maybe, what kind is it? Why was it cleared? Most likely if it is not a hard counter, you can not make up a counter that works for you.
Jul 28, 2009 | Office Equipment & Supplies
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scann
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
How to find meter reading on KM-1500
I believe you hold down the Clear/Stop botton and hold it and you will see PT- in the display then it will show the Total count in three sets of #'s in the LED display. It may also be that you hold down the "0". It's been awhile, but it is one of the two.
Mar 26, 2008 | Kyocera KM-1505 Copier
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,189 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
