I have not used this router in some time and for some reason my laptop has not retained the network key. How can I reset that so I can get my laptop to run off of it?
You can log into the router(by plugging up to it and typing its ip address in a web browser address bar) and click on the wireless tab! If you had mac filter enabled or forgot the password you might experience difficulty, in that case you can reset the router! (If you forgot the ip of the router simply plug up to the router and check the ipaddress, The gateway is the address of the router!)
To reset the router: Behind the router should be little hole that says reset. Inside that hole is a button that you can press using a pin or straightened out parerclip. With the power on press and hold that button for 10 - 20 secs. You'll know when the router resets because if you look at the lights at the front they will flash! After that you can access the router by logging in to it with the default ip address 192.168.0.1!(type it in a web browser address bar)
After that you can configure the router!
post back if you need further assistance!
regards, babb
Was this helpful?
Yes
No
Popular Solutions for D-Link AirPlus DI-524 Wireless
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the...
(More)
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the internet at the same time. It also drops when I get an incoming message on my blackberry.
my computer is upstairs and the router works fine on this one downstairs, I cant find the disc for...
(More)
my computer is upstairs and the router works fine on this one downstairs, I cant find the disc for my computer wireless card upstairs?
when i go through router setup it locks out my laptop. i need securitybut my own access at same...
(More)
when i go through router setup it locks out my laptop. i need securitybut my own access at same time.
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried...
(More)
After reseting my DI-524, accessing it yields screen telling me to update the firmware. I've tried to several time, but it just causes the router to lock up. I've tried reseting the unit again. And, yes I've cycled the power a few times ? no love. Y'all have any voodoo to solve this problem?
