Question about Nintendo Wii Console
Wii remotes working yet?
I'm having the exact same issue - one stopped worked than the other.... I can't seem to sync either of them up again.
  • 34 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
My wii remote doesn't work at all I have brand new batteries in it but it still doesn't turn on. Is there a way I can fix it?
Wii Remote Won't Sync ' Nintendo Tech Forums
techforums.nintendo.com > Wii & Wii mini > Discussions
Dec 29, 2011 - 14 posts - ‎13 authors
I used a digital camera and all lights are working on the sensor bar. Both have new ... That doesn't work obviously. ... I've tried everything on this post and everything that I could find online to resync my remote. Nothing works. Wii Remote Doesn't Work Properly on Wii...
Dec 25, 2013
Wii remote doesn't sync and light up...
Feb 6, 2012
Wii-mote issues - won't sync
Jun 28, 2011
Wii remote doesn't work...
Aug 20, 2010
More results from techforums.nintendo.com
Dec 26, 2015 | Video Game Consoles & Games
Wii fix guide
Try this link it may help. If not there may be an issue with the console or controllers. Try the controllers on a different wii. Try a different controller with your wii. Wii Remote Not Working or Syncing Correctly Wii and Wii mini Nintendo...
Aug 21, 2014 | Nintendo Wii Remote Controller
I can't seem to sync my wii controller. All 4 lites are blinking and will not stop. I changed the batteries and tried to re-sync the controller w/no luck. It was just working a few minutes ago.
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
if nothing else works call 1-800-255-3700
Jul 12, 2011 | Nintendo Wii Remote Controller
My wii remote doesnt work ive just moved house and had to disconnect my wii and now the remotes dont work the console seems fine,ive changed the batteries turned the power on and off and tried to sync the...
It seems like it is a syncing problem. Do the wii remotes flash when you push buttons on them? If they do be sure to try and sync them again. Remember to check the manual on how to sync because it can be irritating at times. Hope this helps.
Mar 02, 2011 | Nintendo Wii Console
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
The batteries went in my wii remote so i replaced them but now cant get the remote to work,,i"ve tried everything i could think of so now asking for your help,can you help please??
You may need to sync up your remotes to your console again.
If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console. Make sure to secure the wrist strap, and have fun!
Nov 24, 2009 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Sep 22, 2009 | Nintendo Wii Console
Wii remote keeps beeping and not working
try this! I found it on Nintendo.com under support:
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
      Try these steps!
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
  • Sep 01, 2008 | Nintendo Wii Console
    Wii Remotes
    Could it be an issue with your sensor bar on top of the TV? That could explain why you'd be having the issue with more than one remote all of a sudden.
    Jun 29, 2008 | Nintendo Wii Console
    Wii Remote Control Stopped Working
    This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
    1) Press the Power button on the Wii console to turn it on.
    2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
    3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
    4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
    This procedure must be followed for each additional Wii remote added to your system.
    This worked for me, hope it helps you.
    Jul 04, 2007 | Nintendo Wii Console
    Nintendo Wii Console Logo
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
