Sharper Image Ionic Breeze GP SI730 Air Purifier
Problem for Sharper Image Ionic Breeze GP SI730 Air Purifier
No power to ionic breeze gp model S1861
By mychevy5 on Jan 02, 2009
I though at first it was just the bulb bad so I ordered a bulb thur bulbs.com , after cleaning it up and puting in the new bulb no lights would even come on. I would like to get a digram of the circuit or find someone to repair it.
Same Problem
Apr 19, 2009
-   I plugged it in and herd a snap. Now it does not work. Does it need a new fuze and cleaning? -   kimirlyn
Mar 22, 2009
-   I have the same problem - 3 of my five aren't working...I thought my bulbs were bad too because some have the dark burnt out look, but I thought the unit should still have power. Thanks for your post I think I will try pulling it apart first like Hpotter said. -   joani1
Best Solution
posted on Mar 08, 2009
Helpful)
hpotter
Rank: Guide
Rating: 94%, 12 votes
You can try this..
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You want to take off the screws from both sides but only remove one side.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Sharper Image Ionic Breeze GP
Questions and Unsolved Problems for Sharper Image Ionic Breeze GP
Do you recommend Sharper Image Ionic Breeze GP SI730 Air Purifier?
Answer
Answer
the clean light does not come on . How do I really know if it's working? there are also two on... (More)
Answer
have there been any health problems reported with this air purifier?
Answer
On the Ionic breeze GP system, the Red cleaning light stays on even after I clean the filter,... (More)
Answer
The unit crackles and hisses even when the unit has been cleaned. Please advise
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Purifiers Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
