Question about Sharp AR-M237 Copier
Hello and thank you for taking the time to help me out. We recently replaced a gear on the copier that interfaced with the fuser. Once put back together, everything was fine. During the day though, the print started to go light through out most of the printed pages, (this included both copied and printed pages). It appears to be associated with the drum unit, as I have removed it and cleand the contact points and now there is about a 5-6" portion of print in the center of the page that is light. The print is also somewhat blurry. Is this an issue with the drum after all or is it the corona wire? I haven't worked on too many copiers and this seems consistent with a drum issue. I truely appreciate your help and look forward to hearing a response from you soon...Regards, Brent
  • 62 Answers
Were the main charge runs in the drum unit is pop lose pushing the black housing into the laser light.
Posted on Oct 11, 2007
    Problem Solver:
  • 5 Answers
You check the optical unit and laser unit glass and cleaning. the next check drum counter process unit counter.
Posted on May 21, 2007
Cover door spring replacement
It helps to have a small tool called a spring hook. Other than that it will function if you tape the cover closed.
blog.equipmybiz.com
May 10, 2013 | Sharp AR-M237 Copier
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
Feb 10, 2011 | Sharp AR-M237 Digital Copier
How to problem sharp AR-M237 erroe code H4-01
you have problem with the fuser temprature maybe the the heater lam or may be thermal fuse just check bothe if ok just reset.
thanks
May 22, 2010 | Sharp AR-M237 Digital Copier
How to replace a pressurization fulcrum arm on the fusing unit of a Sharp ar-m 237 copier
The fuser needs to be removed from the copier first. If you have the part it is not to hard to take the fuser out. Turn the copier "OFF" first & unplug the copier, remove the transfer unit from the right side, then remove the back panel of the copier ( 5 screws ), then unplug the fuser unit ( 3 connector ) , then reove the top right cover ( 2 screws ), then you can see the 2 top screws & the bottom 3 screws, remove them and the fuser should pull out toward you. Replaced the broken fulcrum arm and reinstall the fuser in revese...... Good Luck
May 09, 2010 | Sharp AR-M237 Copier
Sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
Dec 28, 2009 | Sharp AR-M237 Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
Sharp photocopier with error code L4-01
Hello sir L4-001 that's driving problem, check the main motor ,gears belts.
Jun 02, 2009 | Sharp AR-M237 Copier
Pages come out black
It could be toner build up on the fuser rollers. If the jam was pulled from the fuser section.
Where was the jam at?
Nov 20, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-M237 Copier Logo
156 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
