Question about Maytag PYE2300AY Electric Dryer
Dryer does not start - Thermal Fuse is ok.
Maytag Performa wont start.
220V is fine.
Thermal Fuse is ok. (zero resistance)
Door switch is ok. (zero resistance when closed)
What should I check next?
  • 4 more comments
  • jschroter Jan 02, 2009
    oops..It was the thermal fuse. I mixed up the fuses and I checked the high temp fuse first which was fine. The thermal fuse is tougher to get to and it was blown. I end up taking out the whole tumbler which is not needed. For those who want to get to the thermal fuse, first take out the high temp fuse and then remove the heater core by unscrewing one screw. Pull the heater core out and you have access to the thermal fuse. Voila. You dont need to take out the tumbler. FYI for those who venture to change your belt its not that straightforward to route. Check out this link:
    http://groups.msn.com/Appliantology/drye...
  • rhardeman Jan 07, 2009
    Dryer will not start
  • lonnie2001 May 26, 2009
    my maytag performa will not start, changed the therma fuse and high temp fuse, plugged it in it ran but i had the drum out when i put it all back togather it wouldnt start.
  • Anonymous Mar 12, 2014
    Maytag dryer wont start. Its signaling L2 but all household power has been checked and is fine
  • Anonymous Mar 21, 2014
    Seems like a fuse but both fuses look ok. What is next?
  • Anonymous Mar 24, 2014
    I have trouble shot all I know how and it seems that I need to replace the thermal fuse, the problem I am having now is that none of the images I can find look like any of the parts in my dryer. Can you please tell me where I can find a diagram or something that will show me what part to take off and test?
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
Posted on Jan 06, 2009
  • Maytag Master
  • 19,396 Answers
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Maytag Performa Electric dryer. Went to put in load and start-would not turn on. Checked breaker first. Then listed and I could hear the timer clickin on the front panel.Front door panel was full of lint....
In-laws machine did exactly the same thing. Check the thermal fuse.
Turn off the breaker.
Pop the top open with a flat screwdriver (there are two clips at the front)
There are two white wires on the right-side of the burner element, this is the thermal fuse (wires are kinda awkward to remove)
I jumpered these to wires and it started right up.
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
Wont start at all.....its a maytag performa
Hi..
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Thanks for using fixya!
RegardsPCmania
Sep 16, 2009 | Maytag Dryers
My maytag performa dryer stopped working. The
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 12, 2009 | Maytag Dryers
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will not turn on.! It shut off by itself while doing a load and i have not been able to turn it back on since.
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 04, 2009 | Maytag Performa PAV2200
Maytag Performa Electric Dryer will not turn on
Check the following to address this issue.
3. Thermal fuse
4. Timer/control
Jun 07, 2009 | Maytag Dryers
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
Yes it maybe a fuse problem .But first you want to make sure the door switch is working.
May 21, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
1,463 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
