Question about Philips DIRECTV H20 DTV Receiver
Recording fails to delete
I have a Thomson DTI6300-16. We set it to record a programme which was only 1 hour long, but it is telling us that the recorded programme is 2h 12mins - and in fact it seems to have used even more disk space than that. The main problem however is that we cannot play or delete the programme, and doing either, or just moving the cursor onto this programme results in the unit freezing and the only way to unblock it is by turning off at the mains.
Can you help ?
  • gareth_willi Jan 20, 2009
    No joy - system has frozen again as soon as we try and delete it, but thanks for the suggestion.
Record another programme so that you have something above the dodgy one in your library. Then go back into your library and press down, blue then green really fast. This worked on mine.
Posted on Jan 19, 2009
Hello My "Thomson DT16300 Top Up TV+Digital TV
Try a Video cleaner, and go to "Thomson" website.
Aug 03, 2017 | Thomson Lyra PDP2840U MP3 Player
My Thomson Top up TV box will not record. I go to the TV guide, press the R button. It then takes me to 'Planned Recordings' list. I press R again and the programme I want to record disapperas. I get...
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
Jan 23, 2010 | Televison & Video
My thomson DTI6300 digital TV recorder shows that it is recording but does not stop at the required time. No recording is actually made and the message comes up ''recording failed''. This happens whatever...
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
Jan 22, 2010 | Televison & Video
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
On the Library section of the DT16300 I have approx 8.5 hours of saved programmes yet the display says there is only 18% of disc space left! out of 60 hours recording time?.
After Re-loading the Freeview Channels on 30th Sept, the disc space was nearly full on The Thomson DT16300. Go to Set up in the Menu, choose 'Personal Favourites' this will bring up all the stored Channels, For some reason a lot of the Channels are marked 'ON' each one takes up disc space. De-select every one, the channels stay in the recorder but release disc space. I now have 86% free. Trevor Rushton
Oct 02, 2009 | Televison & Video
My Thomson freeview recorder box wont let me record anything as it saya that my drive is full but it freezes when i try to delete some of my recordings
Marriott, You will find that it is only one recording that is causing this. This also happens to my box as well when we tape emerdale on a Monday. look through what has been taped and find out if the minutes used is correct for that programme. if not then you need to do the following in very quick procession.
Press the delete button and confirm as quickly as possible when you scan down the the programme that has not recorded correctly.
Hope this helps
Norrie
Oct 10, 2008 | Televison & Video
Thomson DT16300 TV Recorder Continually Freezes
Just got off the phone to TopUp TV and they knew how to sort this out.
Follow these steps
1. Turn on unit and press menu
2. choose set-up
3. then choose Help
4. On the help screen type the number 1397 on your remote - This will take you to an Engineer set-up screen.
5. Scroll down to option 7 (disable library video window) and toggle this option to "YES"
navigate back to your programs and delete the recording that was giving you the problem.
Oct 07, 2008 | Televison & Video
Thomson dti 6300 16 top tv version box tuner works but programe lbrary where recordingd are available has frozen cannot access or delete
Hi! This is not a great solution and a bit long winded, but aimed at those who've lost the receipt! Start by recording a new programme - the box should still record. Now the corrupt recording is not the first one in the library. When you press library now, all appears to be well. You can find which is the corrupt recording by scrolling down slowly. The corrupt one should be the one with no thumbnail picture (plus it'll be the one that freezes the box up again!). Restart the box agan and press library. If you have recordings before the corrupt one you should be able to scroll very quickly past it and delete them now. Now the corrupt programme is at the bottom of the library list - you can't delete it but at least you can avoid it now...
Like I said far from ideal, but it works on mine. Still no word from Thomson. Hope this helps.
Apr 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
Philips DIRECTV H20 DTV Receiver Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
